JX95 Low Transmission Pressure light
   / JX95 Low Transmission Pressure light #1
Pkneibert
Leawood, KS
Case Jx 95
I have a 2008 JX 95 that I am wanting to use to run a PTO powered trailer pump. When I back the pump into the water and run the tractor, I'm getting the "low transmission pressure" warning light. The tractor is on a ramp with a 4 or 5 to 1 grade.
The dipstick indicates the reservoir is full.
I plan to run the pump for a couple days to flood a duck hunting marsh and don't want to damage the transmission.
Any suggestions or thoughts on how to resolve this problem?
   / JX95 Low Transmission Pressure light #2
Honestly, in a situation like this, the only real thing that you can do is check the pressure to make sure that it is right. Buying a gauge and a few fittings is all it usually takes. The angle that the tractor is on could be putting all of the fluid away from the pickup and causing it to suck some air instead of oil.
Polaris ATV (A50324)
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A51248)
UNUSED FUTURE SB45...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
