JX85 Hard starting
/ JX85 Hard starting #1
oliver28472
Mt. Ulla, NC
Satoh S-470D, Mitubishi FD 1450D
My brother just bought a lightly used JX85 with 384 hours. It sat in a building without being started for a year or so. It has a new battery and spins the motor over seemingly fast enough but it takes 45 seconds or so to start it.
Even when the engine is warm it is slow to catch. I'm going to use it to bush hog today and have it parked on a hill to roll it off. Any suggestions?
/ JX85 Hard starting #2
Have all the fuel filters been changed? It sounds like water in fuel or an air leak. Too low of hours to be low compression.
I'll have to ask about the filters. I put six hours on it yesterday and it runs fine.
/ JX85 Hard starting #4
Often a small air leak in the lift pump line lets it lose prime and make for hard starts due to the air trapped. Seems to me the fuel line on the JX runs in a pretty vulnerable spot near the step. Make have been hit by stick coming off the front tire or similar.
Thanks, will take a look this afternoon when I get home.
No filters were changed, just fuel and a battery. Going to see what I can see on the lift pump line.
/ JX85 Hard starting #7
If you start it within seconds, does it start well? A small air leak or a leaking foot valve in the lift pump line depending how the JX is setup will cause it to be proportionately hard to start depending on how long it was shut off, up to the point the line is completely dry.
I've now driven it four times. The first was a seven mile drive to my house where I parked it because it was Sunday and low on fuel, not worth bush hogging for just a few minutes. The second time was yesterday morning for several hours after filling with fuel. Again in the afternoon and then this evening. All four times it was rolled off. Now the plot thickens. I was finishing up in one pasture and it just shut down like it was out of fuel. I was using the lights and fan in the cab and had no warning at all. Tried to start with the starter but not even a sound. Still had good strong lights. There must be a glitch somewhere, maybe just a fuse?
/ JX85 Hard starting #9
Your fuel shut off solenoid must be sticking or have a loose wire? Any damage to the wiring?
I don't think so unless it got chewed on while in storage. I'm not too worried about it now, I pretty much finished what I needed to do. It's my brother's tractor, I'm bush hogging for him, he's gone out of town so he can jump on it when he gets back but I'll post the results.
OK I know you've all been on pins and needles so I have a minor update. My brother finally got time to check out his tractor a few days ago. He checked all electrical connections and still nothing. A neighbor was cutting wood at church today and he went out there and did some checking. He wiggles the pto shifter and the starter began working but did not start. After process of elimination, his conclusion is algae in the tank. He applied air pressure and primed and started the tractor. It ran a few seconds and cut off. Said the filters have never been replaced and the back one was dry after it started. Fuel smelled funky. He said the tank will have to come off and be washed out. That's gonna be fun. Nothing else will happen until at least Saturday.
I have some good neighbors! He came back yesterday and rigged up a temporary fuel tank and drove the tractor to his house. The tank comes off today while the owner (my brother) picks up a set of filters at one of his dealers on the way home.
2006 FRAC TANK 500BBL WHEELED (A63569)
2006 FRAC TANK...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2015 WESTERN STAR  4700 SF DAY CAB (A63569)
2015 WESTERN STAR...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
