Just starting negotiations on compact tractor. Guidance
   / Just starting negotiations on compact tractor. Guidance #1
jmt1271
Platinum Member
MO
Kubota L2501
Looking to purchase a compact or possibly sub compact and just now emailing some local dealers.
Wanting basic guidance through the process from the more experienced. Please forgive if repetitive.
I'm going to be purchasing a compact utility tractor, loader and backhoe for our new property shortly.**Either kubota or deere. Top priority is value/best deal. I trust both companies.
*New place is 10 acres, 3.5 in pasture and a barn for a couple horses.*
Mowing is handled with a Scag zero turn and is not a factor with this purchase.*
Maintaining 1000 feet of gravel driveways is. Also needing to dig 800 feet or so of gutter drains, and quite a few French drains as well.*
Additionally, there is a pond overgrown with cat tail that I'd like to clean the banks of.*
As well as basic handling of 2 horses, a barn and small pasture.*
Above was basically what I told the various dealers.
I will obviously be negotiating but initial pricing was as follows.
2018 Deere 2032r with 220r loader and 270b backhoe. Roughly 37k list presently at 29.5 otd excluding taxes.
2018 Deere 1025r with 120r loader and 260b hoe. 24.5 list, 20.5 otd excluding taxes.
Talking to one local kubota dealer, similarly setup B3350 tractor, loader and backhoe is about 27.5k otd existing taxes.
Plan to continue working them until I find a good deal. Thanks in advance for your thoughts.
   / Just starting negotiations on compact tractor. Guidance #2
My first question is, "what's wrong with your 3520?" Other than being just on the cusp of handling round bales with the FEL, it will do everything you need except the backhoe work.
You can hire/rent a backhoe or excavator for the guttering & the French drains.
Your 3520 is also NOT Tier IV... which makes it a very desirable tractor.
Lol that is long gone. I need to update my profile as that tractor was sold when we moved to MO from TN 8 years ago.
You say it's desirable because it's pre the latest emissions bs?
   / Just starting negotiations on compact tractor. Guidance #6
Among those choices, I'd go for the B. Had really rotten experience with a 1025R. Now have a 2025R with absolutely no problems and had a 4010 (e.g. like a 2019E, if they made one today) with no problems except for turf problems with FEL and turnbuckle breaks caused by my own self until the lead U joint disentegrated at 9 years and 660 hours.
Ralph
Ralph
Thanks. I definitely haven't ruled out anything but leaning toward the 2032r or the B3350.
Just thinking long term the additional 9k or so would be well spent on the larger components. Still working it out, a lot will depend on what offers the best deal.
Rough, inappropriate expression.
Lol. Assuming I'm taking you correctly, we just disagree on the appropriateness of my expression.
   / Just starting negotiations on compact tractor. Guidance #9
On the Kubota, be sure to check the hydro whine and hydro pedal before you buy. I didn't like either.
Just discovered how much less crap is on the 1025r than the 2032r. Specifically don't want to mess with regen.
Payment Terms (MUST READ) (A50775)
Payment Terms...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
New Long Forks (A53002)
New Long Forks...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
