just purchased used jd 5085m tractor and do not have a operators manuel.
   / just purchased used jd 5085m tractor and do not have a operators manuel. #1
pwillis
ty ty ga
jd 5085m
using a 7 ft rotary mower. set desired height but unable to set draft control.
   / just purchased used jd 5085m tractor and do not have a operators manuel. #2
Not sure how or why you'd use draft control with a rotary mower, but if you do find out what draft control is, this is how to operate it according to manuals for your tractor that can be found online if you type "5085m manual":
Mechanical Draft Control:
With lever (B) fully FORWARD = No draft sensing. With lever (B) fully REARWARD = Reduces the amount of draft load required to override the depth setting (position preset by lever (A)).
   / just purchased used jd 5085m tractor and do not have a operators manuel. #3
Draft control was designed to be used when plowing with a 3 pt implement but should not be used when height control of implement is desired such as mowing or blading.
28013 (A50322)
28013 (A50322)
John Deere 750 Drill (A50514)
John Deere 750...
John Deere 960 Culitivator (A50514)
John Deere 960...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
