Just purchased older LK3054
   / Just purchased older LK3054 #1
bbse
Platinum Member
Nashville, TN
Mahindra 3325
I have just bought a used LK3054. I believe it is a mid 90's model. Does anyone know how to tell? It is in good shape. The throttle lever is loose and will not hold the RPM's up. I think I can fix that easily enough. It has a Great Bend 260 loader, R1 tires and a new King Kutter RF-60 rear mower w/pneumatic tires. I purchased it for $7500.00. It has 506 hours on the meter. Seller said he had just had the clutch replaced and both front tires are new. Current owner purchased from a nursery where it was used for a lot of loader work. He used only to landscape around his new house. I am very pleased with what I have seen so far though I have not got it home yet. I drove it at the sellers sight. I do have several questions.
1. Are there any problems with older LK3054's that I should look for or expect?
2. Is there a place on line where I can get a owners manual? Or can someone fax me a copy of the critical pages? i.e. fluid change intervals, grease fitting locations, fluid types, etc.
3. Same for the Great Bend loader? I am not sure how to remove it and the seller had never taken it off either.
4. The mower has pneumatic tires. I am going to use it to mow some rougher areas and I am not sure how tough the tires are?
5. I need a 5FT box scraper and I am thinking of the KK unit from TSC. Does this unit have enough weight or would you recommend another brand at a comparable price?
I just sold my Kubota 3010 last week and I chose this tractor as a replacement. My 3010 had a LA482 loader and a BH BX72 scraper. I kept my KK 5' brush cutter. Some are thinking why? Well the Kubota was too big to mow my yard anymore and I had already sold my LP FDR2572 rear finish mower last year. I have built decks, sheds, planted trees, driveways, so forth and so on and I could not maneuver the GST tractor around without doing damage to the yard with the loaded R4's....plus I wanted a lower cost unit to just bush hog and move dirt. I am going to buy a small mower so my wife can mow around the house this summer since will be too busy anyways.
I am very excited to get this tractor home and get some time on it. It will probably be a couple of weeks before I can start bush hogging my fields because of commitments. Look forward to hearing your replies. First time I have posted to the Kioti site. Thanks again. A new old Kioti owner /forums/images/graemlins/grin.gif
   / Just purchased older LK3054 #2
Welcome to the pack /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
   / Just purchased older LK3054 #3
Not sure how this works for older mid-90's units but for mine its the first digit in the SN# is the last digit in the year. so if your is 2XXX-XXXXX, then your tractor would be a 2002 model, and more than likely sold in 2003.
I use a Midwest 6' heavy duty box blade. My 3054 handles it well. I use a Bomgaars (Howse) 5' brush mower which has no problem destroying all sorts of plant life. I have a 6' finish mower which works good if not trying to mow too tall of grass. Mines a 02'. I don't know the history of the 3054s. Jon Depratt or John should be able to answer that easy enough.
Mine runs great. Tilled 5 acres and planted brome grass, then went over it with a spring tooth rake. Used about 7 gallons of fuel for the whole thing.
thx
Jim
   / Just purchased older LK3054 #4
They started that SN# system in 94. If it has 9 digits then you can use that, if it has 8 then you have to get in touch with Kioti or have one of use dealers do it. They now use Letters are at the front of all new tractors example: if it starts with D then its a 2004 E would be 2005 and so on.
   / Just purchased older LK3054 #5
Sounds like a good deal for all that! I can't answer most of your questions as I've only got 160hrs on mine, but I do have the 5' KK Box Blade, and I find it works great. No, it's not the heaviest thing, but it's quite functional, especially for the price. I would buy another. That goes double for the tractor itself, I am quite happy with mine.
New/Unused 7ft 8 Drawers and 8 Cabinets Workbench (A51573)
New/Unused 7ft 8...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
FAKE (A52472)
FAKE (A52472)
2019 HINO 268 26FT BOX TRUCK (A52576)
2019 HINO 268 26FT...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2023 JOHN DEERE 8R370 LOT NUMBER 220 (A53084)
2023 JOHN DEERE...
