Just purchased a trailer sprayer
   / Just purchased a trailer sprayer #1
duster
ARMADA TWP MICH.
BX2200 LOADER,60
I just purchased a 25 gallon trailer sprayer from my local TSC and I was wondering if any other BX2200 owners have one of these and how they wired it to their tractor.The unit comes with a two wire lead with alligator clips, but i would like something more permanent and secure.
   / Just purchased a trailer sprayer #2
I don't have one, but if it were me I would use the wires under the seat. They are there for auxiliary lights/etc. I would probably then add a cigarette lighter plug to the sprayer and a cigarette lighter outlet to the tractor. Simple yet should be effective.
/forums/images/graemlins/grin.gif
   / Just purchased a trailer sprayer #4
This is perhaps a dumb question but why not get the 3-point unit and use a roller pump off the PTO? I have been looking at the 50/60 gallon units, boom poles and hand gun, roller pump for about 400 dollars. I think they would do OK on the BX, since I don't have the unit yet so I cannot say it would for sure but I am pretty dang sure it would do OK on a BX and the 2410 for dang sure. You don't have to fill it up all the way. J
   / Just purchased a trailer sprayer #5
JR, I've used both kinds, and guess you've had enough experience to know that you'll probably want an adjustable pressure regulator with bypass back to the tank with the roller pump. I really like the roller pumps myself. And I would want a filter (just a fine screen wire filter works fine) in the line before the pump.
   / Just purchased a trailer sprayer #6
Thanks for the tip, some things are not so obvious until you start getting all the little pieces together /forums/images/graemlins/smile.gif. J
Thanks for the advise guys.I guess a cigarette lighter it will be. /forums/images/graemlins/laugh.gif
   / Just purchased a trailer sprayer #8
I also added a switch on the dash to control the cigarette receptical and that allowed me to turn on or off the pump very easily. I would strongly recommend adding a switch somewhere.
And I would invest a couple extra bucks and buy a waterproof switch. A cheap switch will cost you a couple bucks, a 100% waterproof one will cost between $8 and $12, but it will last for many years of use.
   / Just purchased a trailer sprayer #9
The cigarette set-up like Bob Skurka's looks to be almost ideal. If you do use the battery clips and run wire all the way back to the sprayer with a disconnect, I would use an in-line fuse somewhere. It'll protect you from having a short start to melt wires and smoke the tractor. Don't ask me how I know this. /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
JOHN DEERE Z920M LOT IDENTIFIER 223 (A53084)
JOHN DEERE Z920M...
8" & 10" I BEAMS & 6" & 8" CHANNEL IRON UP TO 25' (A51247)
8" & 10" I BEAMS &...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
BESTWAY AG VSK50 LOT IDENTIFIER 96 (A53084)
BESTWAY AG VSK50...
2012 Nissan Maxima Sedan (A51694)
2012 Nissan Maxima...
