Just purchased a trailer sprayer
   / Just purchased a trailer sprayer #1
duster
Bronze Member
ARMADA TWP MICH.
BX2200 LOADER,60
I just purchased a 25 gallon trailer sprayer from my local TSC and I was wondering if any other BX2200 owners have one of these and how they wired it to their tractor.The unit comes with a two wire lead with alligator clips, but i would like something more permanent and secure.
   / Just purchased a trailer sprayer #2
I don't have one, but if it were me I would use the wires under the seat. They are there for auxiliary lights/etc. I would probably then add a cigarette lighter plug to the sprayer and a cigarette lighter outlet to the tractor. Simple yet should be effective.
/forums/images/graemlins/grin.gif
   / Just purchased a trailer sprayer #4
This is perhaps a dumb question but why not get the 3-point unit and use a roller pump off the PTO? I have been looking at the 50/60 gallon units, boom poles and hand gun, roller pump for about 400 dollars. I think they would do OK on the BX, since I don't have the unit yet so I cannot say it would for sure but I am pretty dang sure it would do OK on a BX and the 2410 for dang sure. You don't have to fill it up all the way. J
   / Just purchased a trailer sprayer #5
JR, I've used both kinds, and guess you've had enough experience to know that you'll probably want an adjustable pressure regulator with bypass back to the tank with the roller pump. I really like the roller pumps myself. And I would want a filter (just a fine screen wire filter works fine) in the line before the pump.
   / Just purchased a trailer sprayer #6
Thanks for the tip, some things are not so obvious until you start getting all the little pieces together /forums/images/graemlins/smile.gif. J
Thanks for the advise guys.I guess a cigarette lighter it will be. /forums/images/graemlins/laugh.gif
   / Just purchased a trailer sprayer #8
I also added a switch on the dash to control the cigarette receptical and that allowed me to turn on or off the pump very easily. I would strongly recommend adding a switch somewhere.
And I would invest a couple extra bucks and buy a waterproof switch. A cheap switch will cost you a couple bucks, a 100% waterproof one will cost between $8 and $12, but it will last for many years of use.
   / Just purchased a trailer sprayer #9
The cigarette set-up like Bob Skurka's looks to be almost ideal. If you do use the battery clips and run wire all the way back to the sprayer with a disconnect, I would use an in-line fuse somewhere. It'll protect you from having a short start to melt wires and smoke the tractor. Don't ask me how I know this. /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
New Wolverine Skid Steer Root Rake Bucket Attachment 34'' (A53002)
New Wolverine Skid...
1991 Mack RW713 Day Cab Truck, VIN # 1M1AY10Y4MM005693 (A51572)
1991 Mack RW713...
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
