Just purchased 2013 Bx25D
   / Just purchased 2013 Bx25D #1
Msathey
Kubota bx25d
Hello. Just purchased at auction 2013 Bx25D with 550 hrs. Got the operators manual and WSM. Tractor was a Home Depot rental. I have the following issue. With the key off (rotated far left)and I hook up the battery the dash lights up as if switch is moved to the on position. If I turn the key to the first click (to the right)glow plugs activate. The 2nd click starts the tractor. The ignition will not shut down the tractor I have to manually activate the shutoff solenoid. I’ve ordered a new switch. Shutoff solenoid functions properly when I did the test from WSM. Everything else about the tractor seems to work great. Will do a complete service on it this coming weekend. All fluids and filters. Is there a recommendation on hydraulic fluids. I do like synthetics.
Thank you for your valued time and input
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A48836)
1989 Chevrolet...
2022 Wacker Neuson SM100 Mini Skid Steer (A50397)
2022 Wacker Neuson...
2021 CATERPILLAR 259D3 SKID STEER (A50458)
2021 CATERPILLAR...
2001 STERLING WATER TRUCK (A50458)
2001 STERLING...
New/Unused Pallet of 5 Binder and 10 Chains (A48837)
New/Unused Pallet...
