Just pulled the trigger on new 2520
   / Just pulled the trigger on new 2520 #1
Mrh51072
John Deere 2305
Well. I waited all I could. I traded my 2305 with 62 mmm for a new 2520 with 62d and 200 cx loader with tires filled and being delivered tomorrow at appx noon. I traded for 7400 and I think i got a fair deal. I feel like a kid at Xmas. Lol.
   / Just pulled the trigger on new 2520 #4
Sounds good....you won't be dissappointed with the 2520. I got mine late summer last year, and it has lived up to, and exceeded my expectations. I'm very pleased with it.
REV
   / Just pulled the trigger on new 2520 #5
Congratulations. I love my 2520.
If it's not too late, get the dealer to swap the rear tires to the wide offset. It's easier for them to do than for you to do after they're filled.
What's that entail?
   / Just pulled the trigger on new 2520 #7
Mrh51072 said:
What's that entail?
The wheels have offsets built into them so that they will either be mounted to provide a narrow rear track (valve stems facing out), or turned around to provide a wide track (valve stems facing in). To change it, you can't just turn each tire around, because it would reverse the direction of the tread. You have to swap the two wheels side-to-side.
You have to use two jacks to lift the rear axle up enough to remove both rear tires. It's important to support the rear axle with two jacks so that the tractor doesn't tip sideways by pivoting on the front axle, which it will do if you don't support it correctly. Once filled, the tires are quite heavy, and you need to be careful when handling them and trying to roll them around.
Ty so much.
Do the wheels rub or hit something if this isn't done?
   / Just pulled the trigger on new 2520 #10
Does everyone generally set the tires wide are there situations where narrow would be better?
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
JOHN DEERE CP690 LOT IDENTIFIER 70 (A53084)
JOHN DEERE CP690...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
