Just posted some T-8 Stuff for sale
   / Just posted some T-8 Stuff for sale #1
pequeajim
Platinum Member
New Holland, PA
Power Trac 425
I just posted my ad for the 60" Finishing deck, Stump Grinder, and 4 in 1 bucket on here and Craigs List. I am going to keep my PT-425, but use it primarly for it's utility strengths and buy and Zero turn mower for the yard.
Jim!
   / Just posted some T-8 Stuff for sale #2
Hello Jim,
I saw your other post about ZTR's somewhere, but thought I would post here. I am sure you realize that money can get you just about anything. I have used Dixie Choppers for about 20 years, and they are a very good mower. And I still have them. I have cut lots of hills, some as much as 40 degrees, but with a technique that I developed. I had to do this because of what I had to work with. No matter which ZTR you get, they will all slide down a wet steep hill. I learned a whole lot in about 20 seconds, by sliding down a wet hill that I had been cutting for 8 years. I slid down this hill about 30 ft, and then dropped another 5 ft off the edge down to the next level. I also had a front counter weight.
I would have different manufactures/distributors, bring out different mowers, and let them show how they are supposed to cut. A new guy not familiar to ZTR, will not know what , or how to use it correctly.
What you should be looking for is a low center of gravity machine, with as much HP as needed, and I would recommend Kohler. Tires that are a combination of lugs and bars for gripping power. A ROPS bar installed, which can also be used for shade with some adaptation. A machine that is easy to work on. Just for instance, I can fix just about anything on my Choppers. Parts, I can get from almost anywhere. Reliability, check the history on any machine as to factuality, and durability, etc. Determine whether you like the mower deck out front, or in the middle of the machine. They also make front cut flails, which do an excellent job in a variety of situations. If you cut near water, think carefully about seat-belts. Check out how the machine can be moved if broken. High lift blades or Gator blades, etc. Can you tow small trailers with it. How easy is it to attach a vacuum system to the machine. Does the machine come with a grass catcher.
The trick to cutting steep hills, is to cut up at a 45 degree across the hill, and when you get to the top, turn slowly and go down the hill at 45 degrees, at idle speed, and use the hydro to keep you slow, and use the brakes sparingly . Keep doing this until the hill is cut. If you should loose traction, prepare your self for a fast bumpy ride. with no control. Take your time and test all you want. Four wheel drive would be a plus.
You just might find a good deal on a good used machine.
Thanks J_J, as always, good advice. I have a couple of dealers bringing their models out so i can try them out on my property. The local guys that have good reps sell Kubota, Exmark, Hustler, and Scag. The others that sell Ferris, JD and Toro, I would not buy from. I believe I have narrowed it down to Exmark Next Z, and Hustler. I love the really low CG on the new redesigned Exmarks and they have a very nice cut.
Back on my original topic. I am only selling the PT deck, stump grinder and 4in1 to help finance my purchase. I posted them on here and on Craigslist, but am not really sure what to ask for them? I basically took 60% of the deck, 70% of the 4in1 and 80% of the stump grinder which is never been used.
Any help in how much to ask for them would be appreciated...
   / Just posted some T-8 Stuff for sale #4
Jim,
I would keep the prices as you have them. I would however separate and post pictures and maybe explain more about each item. Such as made in America, hydraulic driven, made for skid steers, and tractors with at least 8 GPM. I would mention the thickness of the metal. ease of maintenance. Maybe mention something about adaptation from the Quick Attach to skid steer or tractor. Anybody could use the stump grinder. You might even put pictures of the implement mounted on the PT, saying something to the effect, made for Power-Trac, but will fit on other hydraulic powered machines. If other other machines has a hydraulic output greater than 8 GPM. a flow divider could be used to divide the flow so that only 8 GPM goes to the hydraulic motor.
Thanks J_J, I will do that later today...
   / Just posted some T-8 Stuff for sale #6
Jim,
Just a warning. Watch out for those stupid idiots , that monitor Craig's list and offer to buy your products, and want to send you a money order for more than the amount off the items, which you send back the difference, and they have a third party to take care of the shipping. They usually don't write good English.
Jim,
Yeah, I ran into one of them one time. Baited him into sending a money order and sic'd the FBI on him. Never knew if he got caught or not.
I broke the ads out individually.
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
2014 Audi Q5 AWD SUV (A56859)
2014 Audi Q5 AWD...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2014 CATERPILLAR...
