Just Little Bites ...
/ Just Little Bites ... #21
You're gonna be surprised how fast that fills-in with gravel from upstream. You can't drive much in that loose gravel either.
Bucket can scoop out loose gravel! :cool:
About 1/2 a mile from the spring where this creek starts ...
It worked!
I got 350 gallons pumped out to water my trees yesterday!
I got home late this morning, and put the BH back on, and went down to the creek again ... My thought is I want to make the creek crossing wider, the the water flow will be more spread out once it starts to flow, and hopefully not wash out this spring ...
I figure if I can push the whole bank back about 3'-4', and keep the same level of the creek crossing it will be a good afternoons worth of work!
It was nice T-shirt weather, eventually the clouds came in, it forecast to storm tomorrow ...
So I started digging! Widening the reservoir to get it to open up into the crossing better ...
There is a reason this area is called Rocky Hollow ... Fortunately none are big! (And I'm not using a shovel & wheelbarrow!)
Scoop it ever which way I can ... Just little bites at a time ...
Gotta build the ramp back out for the crossing, it needs to be more gradual to get the mower across ...
Got the ramp the way I like it, while I can go up it with this little tractor, I need it 3 times as wide for the mower ...
I added all the dark dirt today! 🤠 😁
Done for now ...
Yeah, that was at 17:40 ... We had a high of 76°!
But it won't last ... Not normal for here,, this time of year, local weather station is saying a few records were broken ...
This now at 02:45 it saying ... But I'm.leaving in a bit to go down near Houston, TX c
Got home today and was on my way to do a fencing project, and swung by the creek, it's full and flowing, I'm quite happy that I widened the creek crossing as it seems to spread out the volume, as long as it stays the same as this, the grass will take over most of it ...
Was out today digging a little ditch, taking little bites with the 6" trenching bucket ... Found a BIG rock!
It stuck out of the bucket about 16"-18", Little Baby Fergie definitely knew it was back there when we took off with it!
The expansion is still holding up GOOD, I'm very happy with it, went down to get a load of water yesterday, as we haven't had much rain recently ... I saw a few small 3/4" long fish, not sure where they came from, but they like the pond! Hopefully it's deep enough now to hold them through the summer!
I also saw a small 1" long crayfish/crawdad, and a bunch of pollywogs ...
A bit of a too full load!
/ Just Little Bites ... #32
Nice project! I envy your ability to do it. The DEP would throw me in jail if I attempted to do something like that around here.
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2017 CATERPILLAR 259D SKID STEER (A65053)
2017 CATERPILLAR...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
2016 Great Dane 48ft. T/A Refrigerated Van Reefer Trailer (A64556)
2016 Great Dane...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
