Just inherited a YM 2500
   / Just inherited a YM 2500 #1
NathanB
Hello everyone,
This is my first post. I'm in Mobile, Alabama. I recently inherited the use and maintenance of a Yanmar labeled as a "YM 2500". The engine seems to run fine. My main problems are with the hydraulics. Yes, I've searched the forum posts and haven't found my exact issue mentioned.
1. My biggest problem is that the darned implements won't stay DOWN! It seems that the spring under the seat always pulls the lever back "up", causing the implements to raise. I simply cannot make the implements on the 3 point hitch stay where I want them. If I somehow finagle it to where I want it, any bump causes the spring to pull the lever back "up". What gives? Why is that spring even there?
2. Also, the "knob" under the front of the seat apparently locks the 3 point hitch in place. That works fine. But I'm unable to find the "lever" that supposedly adjusts the speed at which it raises or lowers . Does anyone have a web page detailing this in pics?
3. Also, from the rear what's the lever on the right side of the 3 point hitch? It moves back and forth but I cannot figure out what it's for.
Thanks for listening,
-Nathan
   / Just inherited a YM 2500 #2
That leaver locks the hitch in place. Does the leaver that raises the hitch up& down stay in place when the hitch goes up & down?Or does it move also? If it moves causing the lift not to stay in place , tighten up the inside nut that holds this leaver on.
   / Just inherited a YM 2500 #3
1. I don't know about a spring. My 1700 does not have a spring.
2. You are correct about the knob. The drop rate lever is nearby. It is next to to a macaroni shaped vent tube. The lever is about an 1" long and controls the speed that the implement moves. Sorry I don't have a pic.
3. I think that may be the drop rate lever
Another Yannie in Mobile.. We are getting popular
   / Just inherited a YM 2500 #4
Hi NathanB. Great to have another yannie in town. I'm in Wilmer and just got my YM240 recently.
I'll check the spring thing on mine.
Welcome.
   / Just inherited a YM 2500 #5
Welcome Nathan from a proud owner of a YM1500 in Morgan County Alabama. I'm sure someone will answer your question.
Bob
   / Just inherited a YM 2500 #6
I know the spring you are talking about.I don't know what part it plays , but if you take the spring off the hyds. won't work.I've tried it.
   / Just inherited a YM 2500 #7
I believe it is the lever that locks the 3 point in the up position.
   / Just inherited a YM 2500 #8
Some pics would help...........
   / Just inherited a YM 2500 #9
The Alabama folks are really showing up lately.
<font color="blue"> War </font> <font color="orange"> Eagle </font>
   / Just inherited a YM 2500 #10
I had a similar problem with my YM1500 when I first got it. Not sure if the 2500 is similar but the problem with mine was a worn out washer.
The lever that operates the 3 pt on mine has a bolt that runs through the lever and through the slot on the plate it rides against. There is a small spring and a couple of nylon washers that ride against that plate. The bolt is adjusted to provide spring pressure against the nylon washers to hold the lever in position. I hope I'm making sense here.
The problem with mine was that the nylon washers had worn to the point that they weren't applying any friction pressure to the plate no matter how tight I had the spring. I replaced the washers and my problem was solved.
UNUSED 72" HYD ROCK GRAPPLE BUCKET (A51248)
UNUSED 72" HYD...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
2015 Infiniti QX60 SUV (A51694)
2015 Infiniti QX60...
2012 CASE IH 1230 LOT IDENTIFIER 243 (A53084)
2012 CASE IH 1230...
