Just got my 3320, but I have a bucket question
   / Just got my 3320, but I have a bucket question #1
FLYBOY1
it has the 300 bucket on the front. Right in front of your feet where it connects to the big round metal arms that bolt to the frame. It seems to float on that instead of being tight. The uprights seem to have a lot of play in them. Is this normal? It seems like it will come lose and bend the frame eventually.
   / Just got my 3320, but I have a bucket question #2
Go to the 50 hour maint in the owner's manual, and follow the instructions to adjust the latch cap screw. If you don't intend to remove the FEL often, remove any gap between the screw and mast pad (step 6b) and then snug it up against it a bit more. This will prevent the latch from rotating, but it will take out more slack.
I have had my 3320 for a year and only took the FEL off once, and that just to do it. Mine wiggle ever so slightly, but not much.
I also recall that some dealers put the mounting frames that the posts attach to on the wrong sides. I might be thinking of something else on that one though. If it wiggles too much, call the dealer.
Checking Parking Latch Cap Screw
Adjustment
1. Be sure loader is equipped with materials
bucket, 4-in-1 bucket or grapple bucket.
2. Attach loader to tractor
3. Start tractor engine and lower ballast box
or rear implement to the ground.
4. Dump bucket 10-20 degrees and lower to ground.
5. Retract lift cylinders, raising front wheels
25-50 mm (1-2 in.) off ground. (Do not
retract lift cylinders completely.)
6. On both sides, make sure latch is fully
seated against brace pad and latch pin
is engaged with leaf spring. Cap screw
should contact mast pad. If not, adjust
each cap screw as follows:
a. Loosen locking screw.
b. Turn cap screw until it makes contact
with mast pad but latch is still free to rotate.
Thanks. I will do that. I don't intend to take it off for anything. I took the backhoe off today to put on the scraper. It was easier than the Kioti was. I like this little machine so far. I only have 5 hours on it so far but I have only had it for a day. It has more power than the Kioti did by a lot, but that was a short about 10 hp. Looking forward to putting the hoe back on and trying it out.
2003 John Deere 6420 (A50120)
2003 John Deere...
New 4-12-16.5 Bobcat Tires & Rims (A50774)
New 4-12-16.5...
John Deere TX 4x2 Gator (A50121)
John Deere TX 4x2...
1985 AM General M35A2C 2.5 Ton 6x6 Fire Rescue Truck (A50323)
1985 AM General...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
