Just finished building CUT backhoe!
   / Just finished building CUT backhoe! #11
That is really a neat looking project you should be proud. I hope it always works well for you.
   / Just finished building CUT backhoe! #12
Thanks for getting back to me. I am going to order plans, I was afraid my flow rate would be too low, (about 3.75 GPM) and was worried about having to use a PTO pump etc. I too have a power beyond valve on my 608 loader. The tech support from Cadplans / MetKit is excellent! John helped me out a lot when I built the loader, even on Sunday evening!
Matt
   / Just finished building CUT backhoe! #13
Built your own backhoe...that is too cool!!!!
It looks like it's standard mount to the 3PH. I assume you stabilize by lowering the 3PH till the "legs" dig in?
Or am I missing something?
Nice work. Good color
Thanks. Yes it does hook to the 3 point hitch and I was concerned that the tractor wouldn't be able to lift it, but has no problem at all, even with the bucket fully extended. when I get to the spot that I want to dig, I lower the 3 point and drop the front bucket so the rig wont roll, put in neurtal, and start digging. The one thing you cant do is push down with the bucket cause it raises the 3 point hitch. You have to clamp the ground inbetween the bucket and the stabalizers.
   / Just finished building CUT backhoe! #15
I would install a chain/bar from top link to hitch to stop the BH from being pushed up. The plans I look at had a whole page about checking the tiedowns every so often and other safety info. They even said a young man was killed when the BH pushed up and he hit his head on the ROPS. I going to order a kit in the spring.
   / Just finished building CUT backhoe! #16
Yes, many people get killed because they dont actually know what they are doing, or forget to check what others are doing.
Few months ago, my brother saw a road constructing employee die, because he got under a tractor and earth dumper that was revesing, he minded his own work, didn't hear the tractor because he was operating an air hammer and forgot to keep an eye on the tractor.
I appreciate the info on the three point hitch. Will add chain to make it safer. Where can I find the safety info on the BH.
Thanks
arkydog
   / Just finished building CUT backhoe! #19
I can't find the site that had it, /forums/images/graemlins/confused.gif but will look again.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2021 Caterpillar 308 Midi Excavator (A55973)
2021 Caterpillar...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
