Just changed the hydraulic oil in my B7510 HST for the first time.
   / Just changed the hydraulic oil in my B7510 HST for the first time. #11
The dip stick variations are, I think, caused because air bubbles from the previous run are trapped in the dip stick tube and push out fluid. Once you pull the stick the fluid rises to its proper level and shows once you insert and extract the stick. Make sense?
   / Just changed the hydraulic oil in my B7510 HST for the first time. #12
How to tell where the fluid is on the dipstick:
I just pull the dipstick and gently lay it on a piece of cloth (my pants) or leather (my glove) or paper towel.
I had the same problem with seeing the oil level on the shiny dipstick. So I cleaned the dipstick, took it to the kitchen, turned on a propane burner, and gently heated that end of the dipstick until the steel was blued for a distance of a few inches. Let it cool normally. Now the oil level shows up well. Have no idea why Kubota - and many other manufacturers - don't do that simple chore for us.
rScotty
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
71061 (A49346)
71061 (A49346)
1981 Case 245 2wd tractor with Rotary cutter (A51039)
1981 Case 245 2wd...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
