Just can't get a good basic truck, like the old days!
   / Just can't get a good basic truck, like the old days! #1,031
I just looked at a Tradesman spec online. For $41k I get less power, less towing capacity, less payload, a smaller fuel tank, and 2 wheel drive with no e-locker. My 2013 F150 STX 4x4 has less junk on it, and is more capable. Once I get above $40k it doesn't matter a few thousand more to get what I would rather have. That doesn't seem like a good option to me. The STX is in my opinion one of the better values.
I used to own a Dodge Ram. I looked with an open mind and did not really like what I see on the Tradesman. The only thing I could see it better on is MPG, and not by enough to matter. I am comparing this to a new F150 with the similar specs to what I have, not my old one. I did not look into what deals are available currently.
   / Just can't get a good basic truck, like the old days! #1,032
A Ram half ton is coil springs in the back and by far the least capable of the big 3 half ton trucks.
   / Just can't get a good basic truck, like the old days! #1,034
So, lets say any one of the big 4, in a 1500 class, moved payload upto 2500#, but also all came with air bags; would you avoid it for the complexity or be intrigued by the added capabilities?
   / Just can't get a good basic truck, like the old days! #1,035
I was talking Ram HD Cummins, not 1/2 tons.
A 1/2 ton in MY operation would be useless as teets on a bull.
   / Just can't get a good basic truck, like the old days! #1,036
Me - definitely avoid. Can't beat the simplicity and load-carrying ability of leaf springs. These new trucks are complicated enough without adding air suspension to the mix. I've read of multiple cases of air suspension failure, disabling the vehicle. Don't hear of leaf springs failing!
   / Just can't get a good basic truck, like the old days! #1,037
Actually yes you do. Class 8 trucks break springs all the time. It’s common enough that you’re supposed to look through over the spring packs in the pre trip inspection. Breaking them in pickups is less common but they do wear out. I changed them on my last ton truck because it was riding on the overload spring unloaded. The air ride assist idea isn’t new either. My mom had a suburban in 2002 with air assist suspension. I bought a Nissan armada from a guy I worked with that needed cash and it had the same thing.
   / Just can't get a good basic truck, like the old days! #1,038
Is that your final answer? :D I've replaced many leaf springs and spring sets over the years. I've never had a catastrophic failure, however.
   / Just can't get a good basic truck, like the old days! #1,039
So what are you doing to destroy leaf springs?? Been through a lot of vehicles in my time...both pickups I currently own are over 20 years old. I have NEVER had to replace leaf springs and don't know of anyone else who had to replace theirs. My 2004 dually lives with a 3000+ lb camper in the bed and has for many years and the springs are still going fine. No sagging.
   / Just can't get a good basic truck, like the old days! #1,040
I’d like to have a pickup with 100 percent air ride like class 8 trucks. There’s no need for springs and air. That’s just more complexity that isn’t needed. The reason I’d like air ride is to air up and down under the trailer hitch. Yes I realize they make hydraulic jacks but it isn’t practical to get every trailer with that.
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
ATV (A59231)
ATV (A59231)
Electric Drill (A57453)
Electric Drill...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
Forklift (A59228)
Forklift (A59228)
296385 (A57192)
296385 (A57192)
