Just can't get a good basic truck, like the old days!
   / Just can't get a good basic truck, like the old days! #511
I like my GMC 25-3500trucks and my Chevy 4500 cutaway there's grease fittings on the ball joints steering box pitman arm. Spline shaft for the drive shaft unfortunately u-oints are all still sealed when, I have to replace them I'll go with graaseable ones.sealed one these days Definitely seem better sealed more durable with grease that doesn't dry out like earlier versions though.
   / Just can't get a good basic truck, like the old days! #512
Myself, if I had to haul anything over 12,000 pounds, I'd buy a used class 8 truck and do it better, and safer than a new $100K pickup. And if spec'd right, get the same MPG.
I already know a guy with a Kenworth with a 450 Paccar in it and he's getting better mileage than his new Ram pickup.
I don't completely understand the different class designations of more commercial type trucks besides a smaller consumer Chevy 4500 !is considered a ton and a half?was told by numerous more knowledgeable people by putting air helper spring on my 2500;I upped its capacity to a ton and a hal. Is there something somewhere that easily clarifies these classes? To occasional heavy haulers on a more part time consumer evel?
   / Just can't get a good basic truck, like the old days! #513
"And, of course there are 100+ different tire sizes in use."
Sons trucks have 14s and 16s; work truck has 17s; me and wife both have 20s; but I can see 14/15/16/18/20/24; but so we need 17s, 19s, 22s? Not really. At this point, I think its easier to find 20s than 16s.
But thats not new either; remember 16.5s, 19.5s; or 7 Ford wheels.
We have a number of vehicles.. F150 has 17s, Escalade has 22s, F450s have 19.5s, Macan has 21s, Another F150 has 18s, Tundra has 20s, Jeep has 15s, Another Jeep has 20s, ... Its nuts.
   / Just can't get a good basic truck, like the old days! #514
There is talk that things have gotten so complicated... but the small corner mechanics haven't entirely disappeared. And the OBDII readers while a bit cryptic, can be extraordinary in directing diagnoses. A couple of things happened. First the mini-marts are very profitable. But, there are fewer routine tuneups. And, of course there are 100+ different tire sizes in use.
I'd imagine from a mechanic's standpoint having to keep dropping what you're doing to go out and pump gas might get old after a while, especially for the smaller outfits that might not always be able to afford a dedicated pump jockey.
First thing my mechanic where I used to live did when he bought his garage (from his father), was to sell off the gasoline part of the business for that very reason.
And today's young people (and this goes back 30+ years) just don't seem to be as into cars as older generations, so there are fewer young mechanics. What few kids who are into cars seem content to put neon undercarriage lights and a fart can muffler on their Suburu and call it good. :confused:
How old is your son's truck where it has 14" wheels on it?
Even 20 years ago; I replaced wheel bearing, U-joint, ect within first 75,000. Now, thats rare.
Don't forget ball joints. The old Mopars were especially bad in that dept, but no one else's were much better.
On my first Dakota I replaced them 18 times in that time frame. About once per month, same as oil changes. I finally started changing them myself and discovered they weren't getting grease properly.
Funny thing, u joints weren't covered under the drive train warranty.
You've mentioned this before, not sure what to make of it. I've had 2 Dakotas (an '88 and an '01) and neither had any drivetrain issues whatsoever.
   / Just can't get a good basic truck, like the old days! #515
I worked at a gas/service station in my teen years owned by an older friend whom had bought it from the non relative friend whom he worked for. He generally did wrenching while I was mainly a pump jockey but helped out in between by changing tires, helping wrench, etc.
Pumping gas involved checking oil, coolant level, cleaning the windshield. It was a different, slower paced time. It was a fun time as there were always car "guys" hanging around. Lot's of burnouts across the lot.
I learned a lot about mechanics that has served me well over the years.
Exxon wanted my friend to build a new station on that property as the building was getting pretty dated. When they did not renew his franchise, he sold the station and wrenched out of his garage at his home.
   / Just can't get a good basic truck, like the old days! #516
"How old is your son's truck where it has 14" wheels on it? "
1993 Nissian D21 "hardbody"
   / Just can't get a good basic truck, like the old days! #517
I've tried to explain it many times but everybody says the driveshaft was bad.
Even the service department at the Dodge dealer said that. They were wrong.
It had little tiny joints which were so small that you couldn't get a grease gun on the zerk when it was installed. So they would replace but not grease it. I didn't figure it out until I started changing them myself; and the darned things were dry. I started greasing them before installing the driveshaft. They lasted a year (50k miles) that way and should have lasted longer but I wasn't dropping the shaft every month to grease them.
   / Just can't get a good basic truck, like the old days! #518
Sure, if you put air bags on your 2500 you can carry more weight. To a point. What are your tires rated for? And the axle? Not to mention how much fun the lawyers will have with you if there's ever a problem.
Your truck should have a payload sticker on it somewhere, telling you how much weight it was rated to haul. Exceed that, no matter what mods you've made to the truck, and you are "illegal".
   / Just can't get a good basic truck, like the old days! #519
There are electronic fart can noise generators being developed for EVs. Are exhaust smell generators next?
   / Just can't get a good basic truck, like the old days! #520
I always wondered what marketing genius came up with the "hardbody" name, especially given how quickly they rusted out here in snow country.
2025 GPS GT612 S/A 12ft Utility Trailer (A56859)
2025 GPS GT612 S/A...
7ft Metal Texaco Pump (A57454)
7ft Metal Texaco...
Toro Promaster 5000 (A55272)
Toro Promaster...
1998 IMT EZ Hauler Mini Crane with Trailer (A57453)
1998 IMT EZ Hauler...
2011 Toyota Prius Hatckback (A56859)
2011 Toyota Prius...
New/Unused AGT Air Compressor (A57454)
New/Unused AGT Air...
