Just bought first tractor and got ripped off
   / Just bought first tractor and got ripped off #151
Yeh. It's not your fault. :D
   / Just bought first tractor and got ripped off #152
Here is the crack on the inside of the case. As you can see its a long hair line crack. It has been welded on the outside should I have it welded on the inside to. View attachment 483405
Poorboy, from pic you must have it apart?? did you tear down yourself??
and what is the final result???
I built a brace on the outside and epoxy the crack. So far no leaks and I have been using it quite often. But if it breaks I will just probably part the tractor out.
   / Just bought first tractor and got ripped off #154
Glad to hear you made the best of it and are getting some use out of the tractor.
   / Just bought first tractor and got ripped off #155
Everyone has an adventure like this and it's part of the learning curve. It doesn't look like it now but the education could save you a lot more money later in life. It did for me.
   / Just bought first tractor and got ripped off #156
This^^
No one learns from their successes. Experience is what you get right after you need it.
This small mistake saved you from making a bigger one later. Guaranteed.
Glad you got it fixed and are using the tractor for its intended purpose.
   / Just bought first tractor and got ripped off #157
WoW! What a saga. And it only took 90 posts or thereabouts to get to the actual leak quantity.
One thing I have to say regarding what I believe was posted by Hutchman, regarding 11 states consumer protection laws, and those states not allowing AS IS/Where is statements when selling items:
Those laws pertain to RETAIL stores/purchases, NOT farmer Joe Bob transactions, IINM, (if I'm not mistaken).
But the bottom line in this story is buyers should be aware as is possible buying used equipment, especially if it has many years and or hours on it. There is something to be said for buying new, and I get it- not everyone can afford to do so, and sometimes the piece of equipment for a particular task is only available used.
Here's what I used to tell customer's and potential customers who came to my foreign auto repair and sales shop back in the mid-late 80's.
Back then if one was buying a 'cheap' used foreign car, of a certain make like Volvo, Saab, etc., to expect to spend at LEAST $2000, and then to add another $2K to the kitty IN CASE of unexpected repairs. If all of the $$K ended up being spent, then the buyer likely ended up with a fairly reliable car for some period of use, that could likely be sold later if needed to recoup some if not all of the expenditure(s).
This way potential buyers went in with their eyes open, knowing what a realistic expenditure might be for their used car purchase.
The OP's tractor seems to have gotten repaired, somehow, and now without all the legal craziness he might have had to endure had he gone that route. I personally look at court as an absolute last resort, similar to surgery. If it can be done any other way, with reasonable expense and little aggravation - go that way first. JMHO.
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
(2) 225/75D15 TIRES W/ 5 LUG RIMS (A52708)
(2) 225/75D15...
2022 CATERPILLAR 259D3 SKID STEER (A52709)
2022 CATERPILLAR...
PORTABLE HAY FEEDER TRAILER (A52708)
PORTABLE HAY...
Hose Reel (A55787)
Hose Reel (A55787)
CAT 930M (A58214)
CAT 930M (A58214)
