Just bought a MF12G
   / Just bought a MF12G #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I just picked up a MF12G garden tractor at a flea market with a bunch of the implements..(plow, cultivator, front blade, but no mower deck). $300. I don't even know what it's worth. I had been looking for a set of turf tires for my other tractor for pulling my lawn roller around. I figured that this would be cheaper than the turf tires and rims, and this way I don't have to switch them around.
It runs in all gears at all speeds, but it's in serious need of some TLC. Left front "axle" is bent about 20 degrees, seat is all torn up. Pin from the implement lift is broken, and the starter switch or solenoid is bad (I had to jump the solenoid to start it). The paint is dull but all the sheet metal is in fair condition.
The only real issue is the axle. I can deal with everthing else. Any ideas on how to fix it? Are parts pretty readily available for these still?
Also, any ideas on where to get a mower deck?
   / Just bought a MF12G #2
Take the assembly apart and clean all the grease off. If you have a large vice and a set of torches you shouldnt have any problems straightening that way. You may need a small length of pipe on the axle for leverage. Just match up the angle from the side thats not bent allready!
2007 Toyota Camry Sedan (A50324)
2007 Toyota Camry...
(4) Gladiator 12-16.5 Skid Steer Tires (A50121)
(4) Gladiator...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2005 International 4300 Heil S/A Dump Truck (A50323)
2005 International...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
