Just bought a Kubota L2950
   / Just bought a Kubota L2950 #21
Johnbro,
You the man! Thanks to you I found it. And your right...good luck seeing the level. Now maybe you can help me figuring out how to connect my hydraulic winch to my tractor w/o paying Kubota too much for the rear hydraulic block?
take care Larry
Wish I could but I find quantum mechanics just slightly easier than hydraulics. I THINK you'll need to tap the power beyond thingie with another thingie. Hope this helps.
   / Just bought a Kubota L2950 #22
..... maybe you can help me figuring out how to connect my hydraulic winch to my tractor w/o paying Kubota too much for the rear hydraulic block?......
Larry - I went back and re-read your other thread about connecting the hydraulic winch - and about that that spendy connector 99063-93300. Your loader valve may have a PB port (usually labeled PB - might be on the bottom under the valve in your picture #1) they sometimes need a PB sleeve or special fitting in the hose to make it functional. You could power an open-center device from the PB (are the winch's solenoid valves open center?) The are also extra ports on the forward hydraulic block that would work (but a 1500 psi relief mounted upstream of the FEL valve will affect it). Good luck - nice country Clarksburg... until the storm took out Rte 2 our motorcycle gang rode up or down Rte 8 now and then. Take care, Dick B (Buckland)
Hi Dick,
One of the things I use the tractor for is skidding logs out of the woods. We live at the base of the Hoosic Range and the lay of the land is neither flat nor open with lots of wet spots to make things interesting. My thinking is keeping hoses in places less likely to get snagged and why I'd prefer to access the hydraulics from the back instead of the FEL. Apparently I should just get over the idea of it and get the connector. I'm just about finished with attaching the winch to the hitch. Next time your out this way come to visit.
Thanks Larry
   / Just bought a Kubota L2950 #24
I have a 7' 3 pt hoe for sale,,not too far from western mass,,,,zip 12523,,, like new, but a few years old,, jakell2010@gmail.com. Runs off tractor hydraulics, no pump, works 100%, to heavy for my B series
   / Just bought a Kubota L2950 #25
What do you want for the hoe, and pls post a picture......:thumbsup:
   / Just bought a Kubota L2950 #26
$2800. Pm me with your email and I will email pics and what I know about it
Is the backhoe still for sale?
Thanks Larry
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
3 pt Aer-Way (A50514)
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
UNUSED CFG KRW232 WHEELED SKID STEER (A51243)
UNUSED CFG KRW232...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
