Just another UDT oil question.
   / Just another UDT oil question. #1
PA-Kubota
Apollo PA
2008 BX2350
I'm going to help a friend do the 50hr service MX5400-HST and looks like going to need about 12gal. Beside Kubota oil, since tractor supply is close are any of their gear oil meet or exceed the Kubota spec? In my area dealer wants $264 whereas TSC is just over $100.
thanks
   / Just another UDT oil question. #2
Don't change the hydraulic oil @ 50 hours. It's a supreme waste of $$$. Over 26 years experience at three dealers selling CaseIH, New Holland, Kubota and Mahindra. Dealerships have been around since 1963, 1970 and 2010. Not a single recommendation or work order for a hydraulic oil change at 50 hours except in rare instances with obvious contamination.
   / Just another UDT oil question. #3
thanks
I've been using TSC's Traveller Premium Universal Tractor Trans/Hydraulic Fluid in our B2910 here for quite some time.
2295.5 hours on the clock so far and no issues.
   / Just another UDT oil question. #4
thanks
On your friend's new Kubota tractor (50 hrs.), I would not even think about anything other than Kubota SUDT-2.
The tractor is obviously still under warranty.
If there should be a warranty problem, when Kubota discovers that TSC low bidder brand oil was used, it will be curtains for that warranty.
False economy!
In the grand scheme of things, Kubota SUDT-2 can be very cheap!
   / Just another UDT oil question. #5
   / Just another UDT oil question. #6
On your friend's new Kubota tractor (50 hrs.), I would not even think about anything other than Kubota UDT-2.
Doubtful.
Were Kubota to do that (require Kubota branded UDT or SUDT), they would be in violation of US Federal Law: 15 U.S. Code § 2302(c) specifically - the particular provision of the Magnuson-Moss Warranty Act, which prohibits the requirement a "supplier" (aka Kubota) of using "tie-in" products to maintain a warranty of a consumer product:
Magnuson–Moss Warranty Act
The only way they could get away with doing so is if they were willing to provide the UDT ... FOR FREE ... at no cost to the consumer.
But if they are willing to do that, I'd certainly be happy to take them up on the offer ... ;)
   / Just another UDT oil question. #7
As skeptic if not a cynic I believe the "suppliers" skirt Magnuson-Moss by stating any "tie-in" products are OK as long as they meet the "supplier's" specifications. If the tie-in product's manufacturer or marketer claims "Meets all tractor manufacturer's requirements" the "supplier" will try to put the onus on the tie-in. How much justice can you afford?
As a practical matter, most consumers rationalize using the "supplier's" products at least for the duration of the warranty period.
   / Just another UDT oil question. #8
"Tie-in" products refers to products being sold/supplied by the original supplier of the item under warranty.
In this case, that would be Kubota.
   / Just another UDT oil question. #9
My misunderstanding, I thought the "tie in" products were substitutes from other manufacturers. e.g. Fram filters, TSC fluids, etc. So "For best results use only genuine ______ tie-in products or parts"?
   / Just another UDT oil question. #10
In this case, if you put Kubota into the blank above, then yes: that could be a statement that a manufacturer (Kubota here) might well make. And, in fact, many probably do.
However, if they attempted to deny warranty coverage on a legitimate claim - simply because the end user used a compatible part or consumable (fluid, grease, etc.) - then they would be violating Magnuson-Moss and Federal Law.
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2018 International Durastar 4300 Altec LR756 56ft. Insulated Forestry Chipper Bucket Truck (A55852)
2018 International...
Texaco Vintage Decorative Fuel Pump (A55853)
Texaco Vintage...
2022 TAKEUCHI TL12R-2 SKID STEER (A52707)
2022 TAKEUCHI...
10' CONTAINER (A57193)
Kubota K7874 18in. Bucket (A55973)
Kubota K7874 18in...
