Just another landscaping rake
/ Just another landscaping rake #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I have to admit, I got inspired on TBN. Here is my landscaping rake project half way through.
Got tines from agri supply - the medium size - and for the pivot I am using trailer axle from TSC and a piece of tubing.
More pictures to follow:)
5 feet only to be able to take it in the woods.
/ Just another landscaping rake #4
Looks good to me. I went with 6' so it would rake out the tractor track if angled. The spindle/axle pivot is a good idea. I used what was here, didn't even think about that way. Later, Nat
My Kubota is 48 inches wide cross back wheels (turf tires) - I was thinking the same thing about covering tracks.
The spindle is a jeeper's idea. Jeep drivers/builders use it as a pivot for the swing tire carrier on the back of the truck:)
Progress made - finished the 3pt and the indexing plate.
Now question: I was going to use 3/8" grade 5 from TSC to attach tines. The engineer in me says to go washer, washer, spring washer, nut on the bolt. Do you think it is really necessary - or is just bolt and nut enough?
What is your experience with tines - do they go loose in use?
/ Just another landscaping rake #7
I used a 1.5" x 3/8" grade 5 bolt with a flat washer on top and a lock washer and nut on the bottom. They were tightened with an air wrench. After 3 seasons of abuse I have yet to either break or loosen a bolt.
/ Just another landscaping rake #8
I used grade 5 1 1/2" X 3/8" bolts that have the knurled washer built into them cause thats what I had. I used it several times and no problems yet. I would think a lock washer on the nut side would be fine.
Well, the spindle was not such a good idea after all. I sheared it right off while using the rake. There are two index bolts on the index plate and for a while I had them all tighted down, but for reverse tines I just tied one of them and after a minute or so it broke.
I believe it is because the spindle is hardened to hold the abuse from bearings - if I used 1" bolt or tubing or piece of construction seal it would hold fine.
Oh, well, live and learn :D
/ Just another landscaping rake #10
If I had a cold beer for each "do-over" then I'd look like Otis on the Andy Ghriffin Show. It looked like a good idea to me. The spindle is very hard, but I'd think it would be strong enough. Are there 2 plates that has the index holes ? and are they together or maybe a space between the plates. It would seem to me that if the 2 plates are rubbing together then the spindle would be in tension instead of a shear situation, and should be more that adaquate, but maybe I don't know either. Anyway good luck with the repairs. Have you decided how you will swivel it now? Later, Nat
Yes, there are two plates and when properly tighten there is no gap between them.
I am going to drill it out and replace it with a big bolt grade 5. I can still use it like this, just changing the angle is harder than it was intended to be.
/ Just another landscaping rake #12
I'd air arc the old weld out. Lot easier than drilling. That shaft must have been ANSI 1045 or other hi carbon and cooled to quickly. Try preheat to 175 deg F and weld with 308 stainless rod and slow cool. If you are close to Newport News I can give you the carbon rod to air arc and some 308 too.
OK, I am lost. What is air arc? Cutting with oxygen?
Thanks
/ Just another landscaping rake #16
FYI,
I have a 7ft rake and I found that the angle iron beam started to twist so I reinforced it. (See Pics) The tines uses grade 5 bolts no washers but lock nuts. I use it often and it seems to work better now that it stiffer then when it had some flex, it keeps the tines biting in. Not sure where you got your tines but I ordered them for about buck something from a Howse Factory Dealer from the Howse web site. I think King Cutter Tines are the same. I always tell myself the next time I go to the Tractor Store to bring one to compare but I always forget to.:(
/ Just another landscaping rake #17
jarokoro said:
FYI,
thats very good to know. we are making our parts list now for building our own rake and were debating whether or not to use square tubing in front of the angle to stiffen it. i think we will just to be sure. :)
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
Kivel Quick Hitch Skid Steer Attachment (A61572)
Kivel Quick Hitch...
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
