I have a 2008 CK20s HST 190 hours it is starting hard lots of smoke tested the glow plugs and the ohm reading on each one is 1.8 ohms is that to high a reading or are they bad
Thats sounds like you don't have the update MichiganIron (Kioti Dealer) mentioned for the CK20S. Either that or a faulty glow plug timer.lunbrjck said:I haven't tried cranking the engine over but after a few seconds the relay kicks off and no voltage to the glow plugs and the glow plug light does not light up during cranking.
It had been getting harder to start over a period of time. The smoke is bluish white and after it has warmed up it starts fine with no smoke. It is kept in a heated garage and has never spent a night outdoors. Fluid levels are all ok and no leaks of any kind. I will make a call to my dealer the first of the week and see what they say about the update on the plugs and talk to the mechanic there. I will keep you posted and thanks again for the help.
