NWOH_Grizz
Did the 100 hour service on my NH T2310, and removed the fuel filter bowl for the first time. In the bottom of the bowl were a number of very small pieces of a black plastic or hardened rubber. I removed the filter and inspected the small o-ring that seals the top of the filter, and it appears OK. The larger bowl o-ring is OK. There is nothing else in that fuel filter bowl that is black plastic/rubber.
Maybe some flashing from a fuel line or the fuel tank? Don't know where else this could have come from.
Also, it appears that only about a half-inch of fuel goes into the bottom of the bowl when the fuel is turned back on. Shouldn't this bowl be completely full? I had to crack the fuel line to the injection pump to bleed the air after having the filter apart, and it seems to run OK.
