jumping up an down right rear wheels
   / jumping up an down right rear wheels #1
ronald 42
canada
kubota m95x
my 2008 kubota m95x is jumbing from rear right Wheel,feel it pretty bad at higher speed on paved roads,slow on gravel no problem,i just by the tractor an dont no much about it,the previous owner pass away. Any help will be apreciatted,thanks.
   / jumping up an down right rear wheels #2
Was that tire damaged? We had a rear tire repaired with a boot patch once, and it unbalanced the tire so much that it acted the same way on a 100 hp Deere, If the unbalance is bothering you, a set of new tires might be in order for it. Check with your local farm tire dealer, I think they can be balanced to stop the bounce now. Good luck!
   / jumping up an down right rear wheels #3
Could you jack up the affected wheel to see if the rim is bent or if the tire is bulged? if you rotated the tire slowly and looked at it from various angles you might see the source of the problem. I'm not familiar with that tractor, but from a picture it looks like you might need one person to spin the tire while the other looks.
A bent rim or bulged tire might not be an issue at low speed, but at higher speeds could affect ride.
Let us know what you find.
Pat
   / jumping up an down right rear wheels #4
Is rear tire radial or biased ply. If biased ply after sitting for a while it can take many revolutions for tire to get the flat spot removed from sitting corrected especially if inflation of said tire is low below spec's.
   / jumping up an down right rear wheels #5
Is the rear DIFFERENTIAL LOCK stuck on, by chance?
   / jumping up an down right rear wheels #6
Perhaps the tires are filled and have tubes. If theres a pinhole leak in it, its possible that air or fluid leaked thru and formed a captured "bubble" between tube and tire. That could cause many pounds of imbalance and sure lump it up a bit. :confused3: ... Is there ANY fluid seepage at the valve stem?
Does the tractor have more than one right rear wheel?
yes they are biased tire an have been park for long period with low presur 12 lbs,that shoul be the problem,hope it will get better after driving it for a longer ride,thanks for the info
   / jumping up an down right rear wheels #8
I wonder if someone put water in for ballast and now it's frozen. What have your high and low temps been like up there in the Great White North?
   / jumping up an down right rear wheels #9
Don't know about tractor tires, but most vehicle tires will develop a flat spot if left sitting for a long time. 12 lbs may not be that low, for a big tire. I'd find the correct pressure before pumping it up a lot. My L3400's rear turfs run 13 lbs. Just driving it some, assuming you don't see an obvious defect, might "fix" the problem.
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2020 DRAGON ESP...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2469 (A60432)
2469 (A60432)
PALLET OF (20) BOXES OF ARMSTRONG TILE FLOORING (A60432)
PALLET OF (20)...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
