Jumping Glow Plugs
   / Jumping Glow Plugs #1
JoelD
Veteran Member
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Is it possible to jump a glow plug? Can you use jump pack and hook negative to engine block and postive to the glow plug to get them hot?
Thanks,
Joel
   / Jumping Glow Plugs #2
interesting concept- never heard of it being done, but why would you need to do that ? Only thing I seen is youtube showing how to test the glowplugs out of the engine with battery.
   / Jumping Glow Plugs #3
I have "hot wired" glowplugs from a tractor's own battery a few times. In instances of a faulty key switch or similar problem, I can get the tractor running and moved to a more suitable place to do a proper repair. I've been known to run a jumper wire to a fuel shutoff solenoid for similar reasons. Something about working in severe conditions when it's unnecessary becomes less appealing as the years pass.
   / Jumping Glow Plugs #4
You would be better off to use some 10ga wire and a switch that is only on when pushed called a "momentary on".
Chris
   / Jumping Glow Plugs #5
Chris
I don't hardwire them. I disconnect the glowplugs when the heat cycle is complete. A jumper wire with alligator clips is all I use. 'Momentary on' in a different fashion.
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2017 TOP HAT TRAILER 16 FOOT UTILITY TRAILER (A53843)
2017 TOP HAT...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
