Jump starting tractors
   / Jump starting tractors #41
My Brother's auto shop has replaced many, many computers due to jump-starting. He likes it when you do that.
On vehicles without computers it's less criticial. On any of them, it isn't the two batteries that cause the problem, it's when two alternators are pumping juice into two batteries at the same time with the voltage regulator(s) trying to figure out if it needs to crap or make a sandwich.
That can cause problems. Not always. But sometimes it does.
But, hey..... ECM's are cheap these days. If you can even find one.
Either buy a battery once in a while or keep a jumpbox on hand. I don't, and won't, own a set of jumper cables.
   / Jump starting tractors #42
Road service vehicles have a remote plug in connection for their jumper cables. Inspiration for my power mod
   / Jump starting tractors #43
And oh...... Know why your charging unit is called an alternator? Because it makes alternating current (a/c). Your vehicles, and batteries, use direct current (d/c).
The A/C has to be converted to D/C at some point, often inside the ECM. You sending two signals to your computer is..... Uncool.
I just don't know why people still insist on using jumper cables.
"My grandpappy used jumper cables on his old still and if it's good enough for him, it's good enough for..... Hey! What's that darn dog doin' in my bed again?!!"
   / Jump starting tractors #44
My 'starting insurance' back in the '70's was to install a new battery in the company car every 2 years.
The battery was cheaper than calling a tow truck plus I'd have a 3-4 hour head start over my competitors.
Back then most sales reps had those devices that started your car every 3 hours or so.
LOL, when on the road you'd want a motel room far away from the parking due to all those cars starting all night.
My jumper cables and vehicles are all equipped with Anderson quick connectors for easy boosting.
   / Jump starting tractors #45
The alternator itself rectifies the AC voltage to DC, then on to the machine's battery and other systems.
   / Jump starting tractors #46
Old School, yeah, maybe, on some.
Not so much anymore. I think they're putting a lot of that (the rectifier) into the ECM these days. Maybe not
   / Jump starting tractors #47
Not so much anymore
please provide a link to where the ecm is rectifying ac to dc, I have never seen this, let alone heard of it.
for everyone who thinks jump starting is bad, every single motorhome does this every time they start
the house battery's get tied to the start batteries, and 100+ amps flows.
and those with the dual alt power issue, rv's and boats have alternators tied to solar chargers etc.... they are never shut off. no fried alternators.
the fastest way to kill an alternator is under heavy charging and disconnect it with no battery attached. which in a jump start situation never happens.
   / Jump starting tractors #48
Most Chrysler alternators don’t typically contain a regulator, the exception being the analog-controlled application. Chrysler controls the alternator externally. A PCM controls the field current. The voltage regulator electronics are housed within the PCM.
   / Jump starting tractors #49
My 'jump start' techniques.
Always clip onto my vehicle 1st.
Clip 'patient vehicle' + terminal and then ground to the patient's on an engine metal bracket.
Let my vehicle run at idle for a short time to charge the patients battery somewhat.
Only then do I signal patient driver to do a start.
Oh and my HD cables are 20 ft long which helps very often.
   / Jump starting tractors #50
A regulator controls the voltage.... a rectifier converts ac to dc... The rectifiers are still mounted in the alternator.
The voltage regulator is a circuit in the alternator that is controlled by messages sent from the ECU over the LIN bus. Dodge is not the only one doing this. Many of the newer cars do this.
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
2018 Chevrolet Silverado (A56858)
2018 Chevrolet...
2025 GIYI GY-PG72C 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A56857)
2025 GIYI GY-PG72C...
2020 CATERPILLAR 299D3 SKID STEER (A52709)
2020 CATERPILLAR...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
LOT: Assortment of Opened Oil, Coolant, Parts Wash, Hydraulic Oil (A59076)
LOT: Assortment of...
