Jump start tractor with truck?
   / Jump start tractor with truck? #1
AllenArmory
Lavon, Texas 75166
TYM T554HST Cab
My tractor (TYM 554) won’t start and I’m suspecting a dead battery. Can I jump start it with my truck (Ram 1500)? I don’t want to cause any damage to either vehicle.
   / Jump start tractor with truck? #2
Tractor is the same as a truck but with different tires. So long as the battery on the tractor is not shorted out (just low) it can be jumped just like a car or truck
   / Jump start tractor with truck? #3
Sure you can. Hook up to the truck first. Then the positive to the post on the starter if accessible and the ground last to any convenient good metal surface, preferably a bracket mounted on the engine itself. You can use the tractor battery itself if that is more convenient. Safety glasses should be worn! Batteries can and do explode. Rare, but does happen.
   / Jump start tractor with truck? #4
12v battery to 12v battery doesn't care if they are in a tractor, car, truck... just hook up your jumper cables as you would any other time. Be careful, tractors often have cramped battery compartments which make hooking up cables difficult and dangerous, but so do today's vehicles!
   / Jump start tractor with truck? #5
Shouldn't you hook up one (red) positive first (so there's no short circuit path back to neg. post if other end of cables are touching each other or vehicle frame);
then hook up other (red) positive at other vehicle (so if dangling black cables are contacting frame it's no big deal)
then hook up black negative cables?
Basically, I forget this and just make sure red cable doesn't touch black cable or frame.
   / Jump start tractor with truck? #6
I've been doing it that way for 25 years, I've watched my dad do it for most of my 38 years on this earth.
   / Jump start tractor with truck? #7
That does make some sense to do it that way. I always just clamp the positive to the insulated negative cable behind its clamp so they don't arc, or if I have a second person, I have them hold the other ends apart while I hook up the jump vehicle.
   / Jump start tractor with truck? #8
I was taught that you should first hook the cables up to the vehicle being boosted , not last. Presuming you have been trying to start it before boosting there is a slight risk of fumes; therefore if there is an arc when you hook up the cables it will be farther away. That was 40+ years ago though, ideas may have changed.
The farmer I worked for years ago would pull his truck up until the bumper was touching the tractor, negating the need for a ground. That won't work with today's plastic bumpers though.
   / Jump start tractor with truck? #9
if you are worried about the battery just drag it with the truck and pull start it - unless of course you dont have someone to drive both ;-)
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A58018)
1998 CHEVEROLET...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
(4) FORD 255/65-17 TIRES W/ 6 LUG RIMS (A58374)
(4) FORD 255/65-17...
