Jubilee rotor clockwise or counter clockwise?
   / Jubilee rotor clockwise or counter clockwise? #1
MarlinSlayer
Collierville, TN
Ford Jubilee!
I posted on here a few months back about being a new tractor owner and replacing disy parts.
Rebuilding starter and never checked to see which way disy turned. Can't crank the motor to tell as starter is now dead. After I rebuilt everything , I double checked the firing order and only got a loud backfire before old starter quit. I never pulled disy, just replaced points, plugs, and wires, so timing shouldn't have changed. I just assumed a clockwise rotation....but if it's counter clockwise then I've got it messed up . spark is strong
Also.... When you pull oil filter to remove starter, how much oil spills out? Is a very smokey starter that cranked fine, then wouldn't .... A typical sign of bad brushes or is it more expensive like an armature?
   / Jubilee rotor clockwise or counter clockwise? #3
You shouldn't have to remove the oil filter to pull starter. I'm away from home but memory tells me ccw
   / Jubilee rotor clockwise or counter clockwise? #4
I first confirmed the firing order from my book 1-2-4-3. Then went to my naa. Standing by the right front wheel looking down on the cap the rotor needs to go clockwise to hit that order. Hope that helps.
   / Jubilee rotor clockwise or counter clockwise? #5
It is 1-2-4-3 for sure, but I'm more than a few nauticle miles away from any manuals. :)
   / Jubilee rotor clockwise or counter clockwise? #6
Yup,mgreynhair getting me. 8n is ccw, naa is indeed cw as you noticed
   / Jubilee rotor clockwise or counter clockwise? #7
Well the op hasn't responded. Hopefully he worked it out. So you are on a boat SG;)
   / Jubilee rotor clockwise or counter clockwise? #8
Giging with a band that does plenty of cruise ship work.
23169 (A50324)
23169 (A50324)
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2013 PETERBILT 367 (A53843)
2013 PETERBILT 367...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
1067 (A53342)
1067 (A53342)
2021 Ford Explorer SUV (A51694)
2021 Ford Explorer...
