Jubilee rotor clockwise or counter clockwise?
   / Jubilee rotor clockwise or counter clockwise? #1
MarlinSlayer
Bronze Member
Collierville, TN
Ford Jubilee!
I posted on here a few months back about being a new tractor owner and replacing disy parts.
Rebuilding starter and never checked to see which way disy turned. Can't crank the motor to tell as starter is now dead. After I rebuilt everything , I double checked the firing order and only got a loud backfire before old starter quit. I never pulled disy, just replaced points, plugs, and wires, so timing shouldn't have changed. I just assumed a clockwise rotation....but if it's counter clockwise then I've got it messed up . spark is strong
Also.... When you pull oil filter to remove starter, how much oil spills out? Is a very smokey starter that cranked fine, then wouldn't .... A typical sign of bad brushes or is it more expensive like an armature?
   / Jubilee rotor clockwise or counter clockwise? #3
You shouldn't have to remove the oil filter to pull starter. I'm away from home but memory tells me ccw
   / Jubilee rotor clockwise or counter clockwise? #4
I first confirmed the firing order from my book 1-2-4-3. Then went to my naa. Standing by the right front wheel looking down on the cap the rotor needs to go clockwise to hit that order. Hope that helps.
   / Jubilee rotor clockwise or counter clockwise? #5
It is 1-2-4-3 for sure, but I'm more than a few nauticle miles away from any manuals. :)
   / Jubilee rotor clockwise or counter clockwise? #6
Yup,mgreynhair getting me. 8n is ccw, naa is indeed cw as you noticed
   / Jubilee rotor clockwise or counter clockwise? #7
Well the op hasn't responded. Hopefully he worked it out. So you are on a boat SG;)
   / Jubilee rotor clockwise or counter clockwise? #8
Giging with a band that does plenty of cruise ship work.
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
1985 International 1954 Grain Truck (A53117)
1985 International...
2014 KENWORTH T800 MIXER TRUCK (A53843)
2014 KENWORTH T800...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2016 Forest River Surveyor 285IKDS 32FT T/A Travel Trailer (A51694)
2016 Forest River...
