Joystick Valve
/ Joystick Valve #11
OK....make sure B1 and B2 are going to the SAME function....and A1 and A2 going to the other.
If you have A1 going to the lift cylinders for raise, and B1 going to the lift cylinders for lower....and A2/B2 going to the bucket cylinders....it would do what you are describing where neither function would work
I didnt say anything about spooling. I said make sure the spools are actually moving.
The spools are the shiny metal round "rods" coming out of the valve and attaching to the joystick handle......when moving the joystick, those actually move into and out of the casting of the valve body. If those arent moving when you move the joystick....you got something else going on
/ Joystick Valve
Thank you LD1! That was it. The lines were reconnected incorrectly. Not only can I now replace the cracked lines I learned something new along the way. Very excited.
/ Joystick Valve #13
Great news and glad you got it figured out
/ Joystick Valve
Also, valuable lesson learned in the course of this. I labeled the lines to make it a little easier.
/ Joystick Valve #16
I have a Montana 4540 model 100 I need a rebuild kit for the joystick mine is leaking wheeler could I find one?
/ Joystick Valve #17
Isolate where it is leaking from. Take it apart to see what size o-ring or quad-ring it has. Take to a hydraulic shop and get appropriate seals.
I have never see someone sell a "rebuild kit" for a valve.
Cushman Electric Cart (A55851)
Cushman Electric...
3pt 26' Field Cultivator (A60462)
3pt 26' Field...
2014 Ford F-550 (A55973)
2014 Ford F-550...
ATTENTION! PLEASE READ (A60463)
ATTENTION! PLEASE...
Kuhn FC400RG (A60462)
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
