Joystick boot
   / Joystick boot #1
DonRybak
Central FL
RK37HC
The joystick boot on my RK37HC has more or less disintegrated from the sun and heat. Has anyone had to replace theirs? If so did you order it from RK or find another brand that fit?? Thanks.........
   / Joystick boot
Ordered the boot today from RK. Hopefully it'll be in early next week. Once it comes in I'll post the part number and price for future reference.
   / Joystick boot
I received the boot yesterday. It was $31.95 plus tax. There's a boot on Amazon for a Kioti that I was looking at that I thought would work if I couldn't get the correct one but when I compare it to the one I got yesterday the height is quite a bit different. The RK boot is 7" tall but the Kioti one is only 4" per the description. The TYM/RK part # is 132015504020 if anybody ever needs a replacement.
   / Joystick boot #4
I found some silicone CV boots in different colors on Amazon for $25 Just cut them down to fit and they work great.
   / Joystick boot
I saw those before. They wouldn't work in my case. Mine are 2 1/8 inches square at the bottom and slips over the control box rather than just cover the hole the joystick comes through.
Also notice the slit in the side of the cover at the bottom. The little dark rectangle. That is where the joystick lock lever comes through. I think if one of the round boots were cut to make that slit the boot would be weakened and tear. Doesn't really make any difference now anyway since I got the boot and installed it.
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
2018 GMC Sierra 1500 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2016 Ford F-350 Crew Cab Warner Service Truck (A48081)
2016 Ford F-350...
UNUSED Heavy-Duty D-Ring Shackle Set (A50860)
UNUSED Heavy-Duty...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A48081)
2013 Crane Carrier...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
