Loader Joy Stick Grip on FEL control?
   / Joy Stick Grip on FEL control? #1
Trails End
Candia, NH
Bobcat CT335
Does anyone know how the grip on the joy stick is
attached to the shaft of the joy stick? Threaded,
molded-on, pressed on?
I'm trying to remove the existing grip to replace it
with a grip with a momentary contact switch/button
for the 3rd function for the FEL, but haven't been
able to remove it yet. Any help or suggestions will be
greatly appreciated.
Thanks, Powerscol! That's what I was looking for. Now I just have to
find a handle with switch to adapt to the existing joy stick shaft.
I may try fabricating one myself, maybe using walnut carved to
an appropriate shape.
   / Joy Stick Grip on FEL control? #4
Save yourself the grief and get the John Deere grip and relays. Numerous folks have posted part numbers. Hopefully your shaft has one hole drilled already, Its a very comfortable grip, especially if your thronging to curl and grab at the same
time. Hope this helps
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2011 CHEVROLET SILVERADO 1500 (A55745)
2011 CHEVROLET...
2000 Mercedes-Benz S-Class Sedan (A53424)
2000 Mercedes-Benz...
ITEM LOCATION (A53084)
