Joy stick control of the dual remotes
   / Joy stick control of the dual remotes #1
joh
Highlands, ontario
MF 1455 Power Shuttle, 4wd, 1040 FEL
Changed from a Mf 35 to a Mf 1455. I'm not liking the complexities of the newer tractor. It has a 1040 loader with a loader mounted joy stick. On the right side of the seat is another joy stick to operate the dual remotes on the back of the tractor. From top to bottom, the remotes are labelled blue, red and the next two are yellow. It's unclear to me which ones work together (delivery and return) and also which outlets do the front to back and which do the left to right function. I'm going to try to post pictures. Help with understanding it's operation would be appreciated! Note, the " yellow " tagged lower hose in the photo, relates to "in" port for the joystick. I ran out of different colours.
That yellow hose comes from the loader mounted joystick. In which I also used blue (delivery) , red (return) and yellow( delivery to the remotes joy stick !). IMG_2677.JPGIMG_2676.JPGIMG_2674.JPGIMG_2675.JPG
   / Joy stick control of the dual remotes #2
If you had a double acting cylinder, you could figure that out in a hurry. There aren't that many combinations. I also use those little colored zip ties for that purpose.
Nice to have two remotes out back. I have never seen remotes on a joystick.
   / Joy stick control of the dual remotes #3
Can't say for sure but as mention with a double acting cylinder it wouldn't be to hard to figure out.
I would expect that the top two connections are one valve and the lower two are the other.
I can't see any reason that they wouldn't be paired that way.
Also if you can watch the hoses and operate the valve you could see the hose jump when the valve is actuated.
   / Joy stick control of the dual remotes #4
Or feel the hose become pressurized.
An operators manual would probably give guidance.
   / Joy stick control of the dual remotes #5
I had my little JD 770 with joystick remotes and the decal had become obscured. It didn't take long to figure out which ports to use for a wood splitter.
   / Joy stick control of the dual remotes #6
A “plug in” pressure gauge would also tell the tale, one port at a time.
Thanks for the suggestions!!
   / Joy stick control of the dual remotes #8
From your pictures, Blue and Red would be a pair of connections.
While the Green and Yellow would make the second pair of connections.
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
Show Livestock Double Blower Stand and Fan Stand (A50515)
Show Livestock...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
