Jousting with the FEL
   / Jousting with the FEL #1
schmism
Super Member
Peoria IL
New holland TC(33)
Front Drivers 31" mud tire - 0 FEL - 1 ;)
what have you jousted!
   / Jousting with the FEL #2
haven't jousted much,
but i HAVE performed some kind of tennis back-hand and smacked a few things-
trees,
garage doors,
barrels/garbage cans
watch out when you're backing up and turning at the same time, especially when you're in the highest of 3 reverses! :D
i should add for proper FEL jousting you need bucket teeth :D
a 31" tire makes a exciting yet terifing sound as you punch a 2" wide slit in the side wall and all the air escapes in about 0.5 sec.
   / Jousting with the FEL #5
Do elaborate!
   / Jousting with the FEL #6
You say it like it's a bad thing....
Could have been worse, could have been the wife's car....
That would have been a "bad" thing!
jb
Glowplug said:
Do elaborate!
i was mowing and makeing a turn up by the truck and came up 2" short.... spun around thinking i was well clear (least 6") of the truck and perfectly stabbed the front tire with the last (corner) tooth on the FEL. RIGHT in the middle of the sidewall...
I couldnt have nailed it anymore dead on if i had tried. another 2" short, and i would have cleared the truck... 2" long i would have taged the steel wheel and at most put a dent in it.....
but NO i had to perfectly stab the tire.... :p
I switched the fronts to my backup set of AT's ...left the muds on the rear.
(i usually like to drop the FEL when i mow... makes the tractor about 5' shorter and SOOOOOO much easyer to manuver around all my yard obsticals... the reason i bought a HST and mmm in the first place) ;)
jb
ya but the wifes car (both of them) ;) NEED new tires... my truck's tires were good for another year+ of wheeling :eek:
   / Jousting with the FEL #9
Took out one of the poles supporting one of the rafters for a pole barn with mine.
   / Jousting with the FEL #10
put a .5 inch dent in my new metal building when I swung around... just close enough to dent it... not rip a hole.. hooray!!!!
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
PIPE WRENCHES (A53843)
Light Tower (A52377)
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
KUBOTA ZD1211 (A53084)
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
