Jonsered 2050 Turbo
   / Jonsered 2050 Turbo #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
It was a great saw and still would be if it wasn't for a guy thinking it needed fixing when it actually didn't need fixing. :rolleyes: So now I may be forced to buying a new one. That little saw has been a great saw and I hate getting something new and not performing like the old one. I hate when that happens. But I seriously think the repairs are going to be expensive and I think I should look at a new saw. Does anyone have any good recommendations for a comparable saw?
   / Jonsered 2050 Turbo #2
What could you have done to it than needs repairs worse than a new carb. Most small engine carbs are around $40 + installation $60 so you will be out about $100 for a new carb and tune-up. Much cheaper than a new saw.
When I first took it in it needed a carb kit. I told him to go ahead and fix it. $70.00 roughly with labor. Saw ran great but leaked oil while not running. I took it back to the guy that fixed it and he said the hose came off. Should be good to go,, no charge. When I got it home I could not get any oil on the chain while cutting so to finish up what I was doing I would just run some oil over the chain every so often.
I looked up Jonsered dealers and low and behold there is an actual small town dealer small engine repair shop in my hometown where I grew up. I know the guy somewhat so I took it into him. He found a cracked oil tube and a hole in the fuel/oil tank. Evidently this is a combo tank and is an expensive part. So I will use the link provided previously here and see if I can't fix it myself if the tank isn't too expensive.
   / Jonsered 2050 Turbo #5
Those are good saws, definitely worth the hassle and looking into. In tractor lingo it would be called a small utility/larger CUT lol. If you ever give up on it I would seek an ECHO CS 500P, no need for a dealer nearby as that thing will never break and always start easy.
It is the old Shindaiwa488 realy which Echo rebadged after they took over Shindaiwa , not as fancy or as high-revving as some newer designs but you wont find a more reliable saw and it is still not quite as much $ as a comparable Husky or Stihl.
   / Jonsered 2050 Turbo #6
2050 plastic crankcase. Mufflers come loose and burn holes in the tank or chains come off and rip holes on that side of tank. I have redneck repaired 455 350 tanks in past and still going without replacing the crankcases.
The saw owes me nothing. It is almost 20 years old and the only thing I have ever done with it was the carb kit and a new safety brake. The safety brake I can't complain when I backed over the saw with my tractor. The hole in the tank according to the guy that just condemned the tank was from the fuel.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
2019 Ford Escape S SUV (A55853)
2019 Ford Escape S...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2016 KENWORTH T880 TRI AXLE DUMP TRUCK (A56138)
2016 KENWORTH T880...
2003 McCormick XTX 185 XtraSpeed Tractor (A57024)
2003 McCormick XTX...
2012 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK...
