Jon Deere D
   / Jon Deere D #1
harneu
Victoria B.C.
J Deere
What is the easiest way to start a D that does not have a starter motor
   / Jon Deere D #2
Do you have another tractor with a belt pulley? A 6' to 8" flat belt, twist the belt 1/2 twist & belt them up, pulley to pulley. Get the D spinning with the clutch snapped out, the engage the clutch.
   / Jon Deere D #3
Open the petcocks to reduce the compression and turn the flywheel by hand.GOOD LUCK
   / Jon Deere D #4
:welcome: to TBN
As mentioned already, plus can you get at it to pull it?
We'd be interested in your tractor find, and what you've found. Rubber tired, or on steel? Age? When did it run last?
Also, we do like pics.. :D
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
New Holland B95 Backhoe (A50490)
New Holland B95...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
