Joint pins/grease & dirt
   / Joint pins/grease & dirt #1
Anonymous Poster
Epic Contributor
I just bought a IH 3414 backhoe and have heard 2 schools of thought on greasing piviot pins that are in the dirt, backhoe bucket and FEL lower pins. Some say grease often but that holds the dirt. Others say no grease, dirt falls off thus longer lasting pins & bushings. An old time farmer said if he greased the round disc cultivator pins they wore out very fast. Is there something that can be done extra like shaft seals to keep the dirt out of the pivot pins?
What does everybody have to say bout this, to grease or not to grease?
   / Joint pins/grease & dirt #2
It often is a fine line between greasing to much and not enough. Not at all is a sin. If the fitting is there grease it and it will purge the dirt out. Grease it to much and it is a collector for dirt but it will block some dirt from getting in but might also hold some in. Often all a fitting needs is a pump a day not till it's running out. Steel against steel wears steel; steel with grease between it wears more slowly.
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
FUEL PUMP W/NOZZLE (A53843)
FUEL PUMP W/NOZZLE...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
2006 JLG 2030ES 20ft Electric Scissor Lift (A54811)
2006 JLG 2030ES...
