Joint pins/grease & dirt
   / Joint pins/grease & dirt #1
Anonymous Poster
Epic Contributor
I just bought a IH 3414 backhoe and have heard 2 schools of thought on greasing piviot pins that are in the dirt, backhoe bucket and FEL lower pins. Some say grease often but that holds the dirt. Others say no grease, dirt falls off thus longer lasting pins & bushings. An old time farmer said if he greased the round disc cultivator pins they wore out very fast. Is there something that can be done extra like shaft seals to keep the dirt out of the pivot pins?
What does everybody have to say bout this, to grease or not to grease?
   / Joint pins/grease & dirt #2
It often is a fine line between greasing to much and not enough. Not at all is a sin. If the fitting is there grease it and it will purge the dirt out. Grease it to much and it is a collector for dirt but it will block some dirt from getting in but might also hold some in. Often all a fitting needs is a pump a day not till it's running out. Steel against steel wears steel; steel with grease between it wears more slowly.
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2015 MACK CHU613 DAYCAB (A53843)
2015 MACK CHU613...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
