joining copper/brass to aluminum?
   / joining copper/brass to aluminum? #1
Haywire
Central Kentucky
Tractorless :(
Is there a weld method to join a copper or brass fitting to an aluminum base? I've got a small aluminum radiator that I want to put compression fittings on for copper tube, but I can't find any aluminum compression fittings that I can get tigged on. All the compression fittings are brass or copper.
Ian
   / joining copper/brass to aluminum? #2
Ian
Not a direct answer to you question.....but when I used to do service on domestic refrigerators I was able to buy aluminum compression fittings that were certified to work and be compatible with both copper and aluminum. check your nearest refrigeration wholesaler
   / joining copper/brass to aluminum? #5
Try Sil-Floss or a similar silver solder product.
   / joining copper/brass to aluminum? #6
You also could try welding an NPT fitting on then you could thread anything into it.
   / joining copper/brass to aluminum? #7
You also could try welding an NPT fitting on then you could thread anything into it. :thumbsup:
Something like this.
   / joining copper/brass to aluminum? #8
The Solders like Al-Solder 500 by harris will do the job but are not very strong. Makes a good good eye catcher at shows but is really limited. We used to solder Stainless to Brass to copper to aluminum in a square and people would buy the stuff although it was weak and fussy. The flux would often burn before the parts were up to temp. I like the aluminum npt idea above.. There are some aluminized copper fittings out there too that solder up. You don't want to use Silver Solder due to the heat it takes to flow out and the aluminum wont like it at all.
That weld on bung fitting might be just the ticket.
Thanks,
Ian
   / joining copper/brass to aluminum? #10
i've seen plastic ferroules.. but .. I'd try a alloy solder rod first.
I've soldered aluminum to both brass and copper using an alloy rod.
use a clean stainless steel brush.
once the alloy is tinned, you can even silver solder to it.
PS.. most of them alloy rods are high zinc content.. so that tells ya what you can and can't join to. IE.. you CAN solder to galvanized with them rods.. etc.
soundguy
20" HYDRAULIC CYLINDER (A51248)
20" HYDRAULIC...
2011 Hyundai Sonata Sedan (A51694)
2011 Hyundai...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
2025 CFG Industrial QH12R (A50123)
2025 CFG...
