Joined the Deere Family - New To Me 6400
   / Joined the Deere Family - New To Me 6400 #1
Old Red
Platinum Member
Western Kentucky
Kubota M6800 HDC
Just brought her home yesterday. 1995 JD 6400 with a 620 Loader. 3,100 hours.
What you all know about these?
   / Joined the Deere Family - New To Me 6400 #2
Congratulations. If you don't already have one, it would be in your best interest to obtain an Owner's Manual. Best wishes.
   / Joined the Deere Family - New To Me 6400 #3
Looks like a good find to me. I need one similar myself.
   / Joined the Deere Family - New To Me 6400 #4
That's a 100HP monster machine.
   / Joined the Deere Family - New To Me 6400 #5
Nice tractor, a couple of models back from my 6415, from the picture I see you have the HD bucket (I wish mine had the HD bucket)
Thanks for mentioning that. I did not realize it. What is the difference?
   / Joined the Deere Family - New To Me 6400 #7
The easiest thing to see is the bucket sides have a reinforcement along the edge. Std buckets only have a small piece at the bottom corner at each side. The cutting edge is drilled for a bolt on cutting edge (your picture was not a good enough angle to tell, you may have the bolt on cutting edge, or not). The welded on cutting edge is longer, front to back than the std cutting edge. Heard heavier metal used for the bucket body.
   / Joined the Deere Family - New To Me 6400 #8
Congratulations, that's a good looking tractor.:thumbsup:
   / Joined the Deere Family - New To Me 6400 #9
I owned a 6300 with the Comfortguard cab back in 1993. It has the Powerquad transmission which gave you 4 speeds in each range without clutching. Of course you had to stop to change ranges but what a slick transmission. I had traded a 4030 with the Soundguard cab which was pretty good for its day but no comparison to the Comfortguard cab. It has the 16 speed quad range transmission which had basically a two speed high-low power shift but fairly crude in comparison to the Powerquad.
I sold it two years later as it was a bit of an "overkill" for my small acreage. But what a fantastic tractor. You should be pleased with your 6400.
When I look at what prices the compact utility tractors with the Comfortguard cabs bring it almost seems to make sense to look at the 6200-6400, or the ten series that replaced them.
   / Joined the Deere Family - New To Me 6400 #10
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
12in Backhoe Bucket (A53472)
12in Backhoe...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2020 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2020 John Deere...
