Johndeere 2012 6630 brake problem
/ Johndeere 2012 6630 brake problem #1
Chris440
/ Johndeere 2012 6630 brake problem #2
What's the brake problem and isn't tractor still covered by warranty??
Oh yes forget about that
/ Johndeere 2012 6630 brake problem #4
Lol at this thread
/ Johndeere 2012 6630 brake problem #5
I have a 6330 and also has a brake problem. they feel like the brakes need bled. dealer says that's normal. I don't buy it. same problem as you are having?
/ Johndeere 2012 6630 brake problem #6
Actually if you have a 6330 and not a 6330 Premium, the brakes do feel spongy in comparison. It is normal for the pedals to travel 1/2 - 3/4 of the way to the floor before brakes activate. We have had some complaints from customers that are used to Deere's full power brakes in earlier models. The non-premium 30 series does not have power brakes. They are manual brakes. They still work well, but definitely have a different feel than power brakes. It is possible that they need bleeding though. I usually try bleeding the brakes as normal setup procedure. Sometimes there is air in them from the factory.
/ Johndeere 2012 6630 brake problem #7
My 6330 brakes took some getting used to. They aren't as sensitive as other 6000 series I've owned but they work fine, just take a little more pressure.
MAGNUM TRANSFER PUMP (A67714)
MAGNUM TRANSFER...
2006 KENWORTH W900 (A67714)
2006 KENWORTH W900...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2018 JOHN DEERE 331G SKID STEER (A65056)
2018 JOHN DEERE...
PORTA POTTY (A68842)
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
