John Deere Z425 23 ohv b&s engine will not run under load or full throttle
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #11
check to see if the carburetor has a plastic needle valve.. if so, you need a rebuild kit with a stainless steel needle valve.. B&S sometimes skimps, but I think it's due to JD demanding it..(JD would get the repair)..
JD would not "get the repair." The dealer might, if the owner took the mower to the dealer. But, JD doesn't make any money from the labor and all JD corporate would get is some amount on parts.
These conspiracy ideas that products are engineered to fail are incredible. JD's gross revenue in 2017 was 26.6 BILLION dollars. How many rebuild kits or needle valves do you think JD would have to sell to affect the bottom line? A million? 10 million? Yeah...that's realistic.
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #12
everything that needs to be replaced adds up, and when JD stops making a needed part, you are supposed to buy a new tractor, which it self, is only supported for so many years.. this IS the way they work.. there's no more of those 30+ year tractors made.. that ended around the '80's...
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #13
Remove the air filter and make sure that the choke flap is open.
Mike.
2014 Volkswagen Jetta Sedan (A56859)
2014 Volkswagen...
2023 John Deere 333G for Parts (A56435)
2023 John Deere...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
LOT: (17 approx. ) Rolls of Chain Link Fence (LENGTH UNKNOWN) (A59076)
LOT: (17 approx. )...
yellow ball Trailer (A56859)
yellow ball...
Quick Attach Bale Spear (A57454)
Quick Attach Bale...
