John Deere Z425 23 ohv b&s engine will not run under load or full throttle
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #1
john94
john deere z425 mower
I have a briggs and Stratton 23 ohv engine on a john deere zero turn 425 mower. It ran perfectly last week. went to start it this week to mow and now it sputters, black smoke and backfires all when trying to give it gas. it will not run fast nor can I engage the blades as the load makes it do the same thing and cut off. I changed the plugs, cleaned the carb, checked the valves, the blades move freely. It starts up and will idle and run on the lowest throttle setting but it will not do anything else. As soon as I try to push the throttle to fast and engage the blades it goes crazy. I don't know what else to try.
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #2
Welcome to TBN
Did you check the fuel pump?
What did the plugs look like? Can you post a photo of them?
Richard
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #3
John I asked for model and type from the engine as well as any recent maintenance that had been do over at Lawnworld, but could you also post that here so in the end it may help somebody else.
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #4
If your engine is a twin, make sure both coils are firing, and you are getting a good spark at both plugs.
Sounds like it is only running on one cylinder.
The model number is 445577-0122-E1
Did notice that the o-ring seal for the intake manifold is cracked so I just picked up 2 to replace them both and see if that does the trick.
the fuel pump is fine the new plugs look good the smoke is just a little bit of black smoke not the white like with a blown head gasket
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #8
In addition, is there a presents of gas in the engine oil? As stated, it could be running on 1 cylinder, though likely would be valve related. Things you want to know on this engine in the valve train. Valve covers off: Are all four rockers operating? The rocker studs tight? Are valve lifts similar? Is the lash set properly?
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #9
John, I wasn't talking about the new plugs. The old plugs will tell you what is going on in the engine.
See the chart below:
Richard
   / John Deere Z425 23 ohv b&s engine will not run under load or full throttle #10
check to see if the carburetor has a plastic needle valve.. if so, you need a rebuild kit with a stainless steel needle valve.. B&S sometimes skimps, but I think it's due to JD demanding it..(JD would get the repair)..
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
Adams 5T Pull-Type Fertilizer Spreader (A56436)
Adams 5T Pull-Type...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
