Mowing john deere x728 ultimate starting issues
   / john deere x728 ultimate starting issues #11
Check both ends of each battery cable. Take them off, clean up and put them back on. Then start looking at the safety switches making sure they work.
   / john deere x728 ultimate starting issues #13
I've just had the same thing with a used X740 that I've got on trial.
It started happening when I found a blown fuse - I replaced it and immediately I got nothing on the dashboard. After about 30 mins I had the ignition turned on while I pulled the new fuse out and the dashboard came on for a few seconds then went blank.
After a bit more messing with the fuses (and connecting another battery - but I'm not sure this is related as original battery was showing 12.7v when not running) it was back to normal. Over the last couple of days it's been fine, starting first turn with no charge light showing.
My theory is that there's a bit of corrosion or a slightly bad connection inside the fuse box.
Hope this helps.
   / john deere x728 ultimate starting issues #14
Did you figure out what was wrong. I have a 720 that is having similar issues. 2 new batteries, from time to time to time even the dash lights will not come on. But hook a 200amp boost up to it and the lights come on and it starts right up. The battery shows it is charging when running. Cleaned terminals and John deere even went through and cleaned all connections. Last night was the first time it has ever died while running? I was pushing snow with the lights on and everything went dead. And not like a kill switch dead, those are slow this was much quicker. Hook a boost/charger and in 20 seconds it's running again.......
   / john deere x728 ultimate starting issues #15
i wonder if these are tied to that single red 10a ? fuse that is behind the side screen in front of the dash... it's a
single fuseholder with fuse that has been known to get wet and hold moisture.i think it hangs near
the relays.
   / john deere x728 ultimate starting issues #16
That's easy enough to get to, and check or replace would that be enough to cause it to die like that?
   / john deere x728 ultimate starting issues #17
Figured it out, or at least for the moment. This time it would not even start with the charger. It was indeed a bad fuse, started pulling random fuses and one a 30 was burnt black and had a ton of corrosion on it. Replaced it as well as took a wire file and cleaned the fuse connections and it started right up. Only Time will really tell if that was the problem. But it defy was for the starting issue.
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2007 Volvo VNL Truck Tractor (A55315)
2007 Volvo VNL...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
