john deere x700 series wont start
   / john deere x700 series wont start #1
eddie7155
i was using the tractor the other day with the tractor shovel and got hung up on a tree stub i was moving.the tractor was on a pretty good incline and justshut down. i checked fuel which was 3/4 full ,checked spark,coolent all the simple stuff (i think?) checked fuel filter could blow air right through it.put the filter back on removed air per operators manual.couldn't get fuel to circulated again.took of seat and pulled the fuel pump fuel pump would run when i put jumpers on it out of the tank.when i put the pump and sensor back in the tank i checked the power at the pig tail comming from the tractor i had power to the tank sensor but not to the fuel pump.is there a fuel shut off thant i dont know about like in a car ? the tractor was running fine before i got on the incline btw the tractor has less than 50 hours on any ideas would help im about 100 miles away from a jd dealer thanks in advance andy
   / john deere x700 series wont start #2
Welcome to TBN:D
Is the tractor still stuck on the incline? If so it could be a low oil pressure condition that is preventing the tractor from starting-I believe there is a pressure switch to protect the engine.
   / john deere x700 series wont start #3
Welcome to TBN Eddie,
How steep is the incline? There should be an oil pressure or oil level sensor that will shut the engine down and this could be your problem. I would also check for any wires pulled loose. If it doesn't start on level ground then you may have other problems.
kenny i have the tractor in the shed which is level is there a reset on the oil pressure switch?
i cant find any loose wires the incline brought the front wheels about 1 foot off the ground
   / john deere x700 series wont start #6
Eddie, it sounds like you blew the fuse in the dash area. remove the side panels, reach deep in the wires, you are looking for a blue fuse with masking tape over it.
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
UNUSED MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED MINI...
2000 FORD F550 SUPER DUTY SERVICE TRUCK (A60430)
2000 FORD F550...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
207279 (A52708)
207279 (A52708)
2021 CATERPILLAR D3 CRAWLER DOZER (A60429)
2021 CATERPILLAR...
