John Deere X530 Hydraulic Lift Lever Replacement
   / John Deere X530 Hydraulic Lift Lever Replacement #1
Ledgemere Farm
Limerick, Maine
A bunch
My lever snapped off, it seems to be a common issue, has anyone replaced theirs and how difficult was it? As in can you replace it from the top or must you get at it from underneath?
   / John Deere X530 Hydraulic Lift Lever Replacement #2
Did the plastic lever break of just pull off the steel shaft? On my X540 the plastic lever will pop off the steel shaft if you pull up on one of the corners. On mine I just pushed it back onto the steel shaft.
   / John Deere X530 Hydraulic Lift Lever Replacement #3
It can be a little tricky to replace. There are several YouTube videos showing the procedure.
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2020 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2020 CATERPILLAR...
2021 Bell TC-11A Crawler Carrier Dump (A52384)
2021 Bell TC-11A...
Generac no start (A51691)
Generac no start...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
