john deere x350 trans engage/disengage
   / john deere x350 trans engage/disengage #1
greenjay
2022 x350
I bought a new JD x350 and notice that the tractor can be pushed easily when transmission rod in the back is pushed in, (engaged) Other mowers I've owned are nearly locked up when engaged. Is this a sign of a future problem, The mower seems to work ok with pedals but is not as fast as other mowers I've used.
   / john deere x350 trans engage/disengage #2
This seems to be normal with the newer machines. I have a X570 and notice the same thing. With the rod pushed in (engaged) I can easily push the tractor forward but I cannot push it backwards. With the rod pulled out it can be pushed forward and backward.
Like your experience, my previous 175 Hydro could not be pushed at all without pulling the transaxle by-pass lever.
thank you
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2013 RAM 4500 (A50323)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2017 International Prostar Sleeper Truck Tractor - Cummins ISX 15 Engine - 10 Speed Eaton Fuller (A53472)
2017 International...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
