john deere x350 trans engage/disengage
   / john deere x350 trans engage/disengage #1
greenjay
2022 x350
I bought a new JD x350 and notice that the tractor can be pushed easily when transmission rod in the back is pushed in, (engaged) Other mowers I've owned are nearly locked up when engaged. Is this a sign of a future problem, The mower seems to work ok with pedals but is not as fast as other mowers I've used.
   / john deere x350 trans engage/disengage #2
This seems to be normal with the newer machines. I have a X570 and notice the same thing. With the rod pushed in (engaged) I can easily push the tractor forward but I cannot push it backwards. With the rod pulled out it can be pushed forward and backward.
Like your experience, my previous 175 Hydro could not be pushed at all without pulling the transaxle by-pass lever.
thank you
2007 34ft. Homemade Pipe Trailer (A55973)
2007 34ft...
2015 Toro Reelmaster 5510D Fairway Commercial Reel Mower (A56857)
2015 Toro...
2011 Ram 1500 Pickup Truck (A56858)
2011 Ram 1500...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58216)
HYDRAULIC TILTING...
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
