John Deere X300 Running rough Quitting while mowing
   / John Deere X300 Running rough Quitting while mowing #1
MajMac392
Southern Maine
Cub Cadet 7234, John Deere X300 Riding Lawn Mower
I have a 2009 X300 Rider and after cutting the grass for 20-30 minutes it starts surging real bad and finally will quit. Sometimes if I push up and hold the choke lever it will continue to run but only for a short while. The x300 with a Kawasaki motor only has 90+ hours on it. When this happened earlier this year I changed the fuel filter thinking that was the culprit but now it's doing it again. The fuel filter never seems to be more than 1/4 full of gas is this normal for a JD? I pulled the fuel line off from the pump to the carb and fuel comes out but not in to great a stream. Does this indicate a bad pump or is a small stream of gas normal? From the parts diagram the fuel pump appears to be a JDUC16533 pump. Any ideas?
   / John Deere X300 Running rough Quitting while mowing #2
Have you checked flow from the tank before the pump? Obstruction in the tank maybe? Do you add any kind of treatments to the gas? Seafoam, MMO, StaBil, etc.?
I don't understand how you only have 90 hours on a 12 year old machine. I have close to 1,200 hours on mine and I don't use it very much.
I always use Stabil in my gas so I don't think that could be it. I'm not sure how I would check the flow from the tank unless just as a gravity flow? I thought about an obstruction in the tank but wondered what it could be. I looked at taking the tank out completely but it wasn't real clear to me how easily it would come out.
Yes, the mower only has 93 hours on it. The area I mow I wouldn't cut more than 8-10 times a season and the last two years have been very dry and I haven't used it much.
   / John Deere X300 Running rough Quitting while mowing #4
I have 2010 X300 with 610 hours on it. Mine did about the same thing but a bad fuel filter was the culprit. I hate Sta-bil it gums everything up, local small engine guy said he would never use that crap. Seafoam works better anyway. I would pull the bowl off the carb and check it for trash and check flow of gas prior to fuel pump as mentioned above. Last resort is getting a new fuel pump. Good luck and let us know the solution you found.
Does the gas filter on your X300 stay full of gas or does just a small amount stay in it? I may pull the carb bowl off but it seems odd it will run fine for 30 minutes or longer sometimes and then it starts chugging and running rough.
Interesting about your comments on Stabil. I’ve used it religiously here in Maine for probably the last 20 or so years on both my 2 cycle and 4 cycle gas, ever since our gas changed. I did switch to the blue Marine grade of Stabil 4-5 years or so ago from something I read I believe.
I’ve never experienced any problem “yet”! I have a wheeled Honda Generator for my house that I keep full of gas. Every Fall I pull it out and start it up and it starts on the first or second pull every time. Some years it has sat all year with no use, so I run it under load for 30 minutes or so, then drain that gas out and put fresh Stabil gas back in.
   / John Deere X300 Running rough Quitting while mowing #6
I sound like a broken record here, but grab a few feet of 1/4" fuel line- hook to the fuel pump and drop the line into a small gas can and see if you have a fuel delivery issue. I have to pull the tanks these to clean for this same condition more often than I would like. One thing that you should be aware of is that putting 8 hours a year on this requires that you be extra diligent on fuel care and selection.
   / John Deere X300 Running rough Quitting while mowing #7
I ran across a similar issue on my mower not long ago. Ran fine for a little while, then it would start acting like it was running out of gas. It had a new fuel filter so I knew that was fine. I disconnected the fuel line at the gas filter and blew air back into the tank to clear out the line. After 20 years I guess I had some trash in the tank. Has worked fine ever since. One day I may have to clean the tank out if it happens again.
As far as your gas filter. All of them on my small engines do not stay full. They only show a little in it at any time. Doesn't seem like it would be enough gas running through, but it is.
Tom, I did pull the fuel line to the carb, put on a piece of hose and cranked it into a container. It pumped fuel but it wasn’t much of a flow, definitely wasn’t a fire hose gushing.
   / John Deere X300 Running rough Quitting while mowing #9
Your fuel pump test is not what was suggested. Very frequently the pick up tube in the tank gets debris which partially blocks the tube. As it runs the pump can either pick up more debris or pack the debris in line and you can't maintain fuel flow. These pumps are not very strong and can't overcome this blockage.
So if I disconnect the fuel line before the filter can I safely blow air back into the tank without doing any damage? I was going to try this but I was afraid there might be an orifice or something else that might be damaged.
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
Barn Wood Picnic Table (A50515)
Barn Wood Picnic...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
